From 99-03 1500's
2 of the Chrome snap on covers have some damage. The rims have some rust. They should clean up nice. You'd probably be better off removing the chrome covers and painting/dipping them the color of your choice.
The one rim does have a very small bend on the outer edge out past the bead surface. It should hold air fine. I have seen rims with much larger bends hold air. 2 of the rims have had tires on them and have held air up until this morning. The other 2 have been sitting tireless for some time.
I'm asking 15 dollars each. Buy 3 get the fourth free. So $45 if you buy all four.
Damage is to the chrome cover. The rim is ever so slightly bent in the same place. 1 other chrome cover has similar damage in the same fashion but that rim is straight.
You can see the damage on the other chrome cover and the surface rust around the edges.
