offroadTB.com • View topic - Confusion
Confusion
by Fisker » Wed Jun 29, 2016 12:51 pm
If I get longer suspension for the front and back of the TB, is there a limit to how high I can go before I run into problems? It seems like everyone here is running a longer than stock suspension, but if we lift our vehicles suspension or body more than three inches we have problems from what I understand. So if we can have longer suspension and 3" lift why is it that we cannot do for example 6 inch body or suspension lifts without running into problems?
Also, I was looking at Hardtrailz build and noticed he at one point had a two inch body lift, are these still manufactured? Finally, Hartrailz how much would you sell your TB for cash in hand?
Fisker
by TBYODA » Wed Jun 29, 2016 1:24 pm
The limiting factor on the suspension lift is CV binding on stock CV unless your willing spend $2k+ on a one off CV's. Most haven't felt the custom CV are justifiable. Beside most would also say it not worth it with our crappy IFS.
Money is better spent towards SAS build if your looking at 37"+ tires.
by Rickalicka18 » Wed Jun 29, 2016 2:41 pm
I believe you can still get the lift meister 3" body lift. That plus the 3" lift kit and stiffer springs should put you over 6" in the front atleast. If thats what you're looking for
Rickalicka18
by Fisker » Wed Jun 29, 2016 3:40 pm
I think in the future when it isn't my DD I will consider doing the body lift on top of my two inch suspension lift. I was more curious as to why we had to combine two lifts to get to 6" instead of doing a 6" suspension lift. and to see if they do the 2" suspension lift still. if that is the case I might could do that and get an overall lift of four inches.
Fisker
by Rickalicka18 » Wed Jun 29, 2016 9:17 pm
The 2" body lift is made by zone offroad. Heres a link to it: http://zoneoffroad.com/zone-offroad-pro ... azer/c9212
Rickalicka18
by larryk » Wed Jun 29, 2016 11:04 pm
larryk
by KingBird » Wed Jun 29, 2016 11:38 pm
KingBird
by SnowBlazer » Thu Jun 30, 2016 3:05 am
SnowBlazer
by TBYODA » Thu Jun 30, 2016 8:56 am
by bartonmd » Thu Jun 30, 2016 11:05 am
by HARDTRAILZ » Thu Jun 30, 2016 12:55 pm
by HARDTRAILZ » Thu Jun 30, 2016 1:04 pm
As stated, the front CVs limit the suspension lift so to get maximum lift we combine the susp and body to get about 6ish inches. Dont want to do more than 3 inch body due to leverage on the mounts.
I did the two inch which is still available before the 3 existed, then worked with Mark to dial in the 3 inch over a few months. I see no reason to do the 2 vs 3 now if you have the option of both. The work is the same for install.
I saw the custom CV mentioned, but I cant recall them actually being purchased by anyone. They seem like the flared fenders and a pipe dream even at the cost named until you have someone step up to buy them. I wanted the fenders, but the real price was triple what had been tossed around here for a good while. I think its possible, but may cost even more than mentioned so bear that in mind.
Never shot anyone down on buying it..Never had someone honestly ask, as you did, for a real price. I have had that in my head for awhile and mentioned it to a few in person.
MDB Fab can do anything if your touch the right spots ;)
by bartonmd » Thu Jun 30, 2016 1:28 pm
by Fisker » Thu Jun 30, 2016 5:12 pm
Fisker
by Fisker » Mon Jul 04, 2016 10:46 am
Hey guys,
on the topic of me being confused and inexperienced, I ran into a small issue while trying to install the two inch rear spacers, however I ran into a small problem. I got the tires off, TB put on Jack stands, shocks off, then lowered the rear diff, however I do not have enough space to get the small spacer and springs out, and certainly not enough to put an inch and a half bigger spacer in. So I went back to the instructions and they say to also remove Panhead bar bolts. I do not know what these are, does someone have pictures or a description of what this is so that I can hopefully get these spacers in.
Fisker
by larryk » Mon Jul 04, 2016 2:23 pm
It's the big bar that goes from the frame on the drivers side, to the axle on the passenger side, behind the axle
Fwiw....if you have jackstands on the frame, and removed both of the lower shock bolts...you should EASILY have have enough room to put them in.
larryk
by TBYODA » Mon Jul 04, 2016 3:51 pm
and remover the sway bar end links. No need to remove the panhard bar bolts.
by Fisker » Tue Jul 05, 2016 8:50 am
Fisker
by Jrgunn5150 » Tue Jul 05, 2016 6:38 pm
by Fisker » Wed Jul 06, 2016 4:24 pm
Fisker
