offroadTB.com • View topic - lift 4"
lift 4"
by zvika ozer » Mon Apr 04, 2016 12:44 pm
Hi.
I have trailblazer 2006 Lt.
I mad 2" lift by springs and shocks,and its not enough for me.I tried to do another lift of 2" by spacer and then it created me aproblem in the bell joints and also in the wheels balance.i tried to turn over the up control arms according to the forums here and that's not good enough,there is still problem in the balance wheels.
I though I would replace the down control arms to abigger size,anyone tried this ???? if so it gave him asolution to the lift ?? I prefer not use body lift Because I want to pick up all the vehicle.
Another thing I order wheels spacer but they didn't fit good on the weel the namber on the spacer is 6-5/6-135
I order awrong one ????
I hope my English okay, I'm from Israel and we do not have a lot of cars Triilbliizr, I was very happy when I found you
thanks you very much.
ozer zvika.
zvika ozer
by bartonmd » Mon Apr 04, 2016 1:13 pm
It is good enough to understand. Not perfect, but good enough.
3" is all we can really do before we bind at the CV / Axle / Half Shaft joint, so even if you change the control arms, if you use the same CV / Axle, you will still have problems.
by zvika ozer » Mon Apr 04, 2016 1:54 pm
Thanks Mike.
I understand that 3" maximum level it can be done?
I see in your on Facebook vehicles that seem higher than 3".
zvika ozer
by Jrgunn5150 » Mon Apr 04, 2016 6:19 pm
by ErikSS » Mon Apr 04, 2016 9:03 pm
We are limited to a 3" body lift due to bind in the steering (you need the provided steering extension in the kit) As Mike said, we are limited to 3" in the suspension as well. Approximately 6" is the most lift we can go without many large custom parts.
by Fisker » Mon Apr 04, 2016 9:30 pm
That being said can you put a 2 inch body lift and a 2 inch suspensions lift without having to add or subtract anything except the lift itself?
Fisker
by Jrgunn5150 » Mon Apr 04, 2016 9:35 pm
by Fisker » Mon Apr 04, 2016 9:40 pm
Fisker
by Anthony Hernandez » Mon Apr 04, 2016 11:42 pm
Zone offroad (bds) has a 2" body lift for around $370-400. eBay.
http://pages.ebay.com/link/?nav=item.vi ... 1472000322
by Jrgunn5150 » Mon Apr 04, 2016 11:49 pm
by HARDTRAILZ » Tue Apr 05, 2016 3:48 pm
The only steering work is to unbolt and bolt in the extension. One of simplest portions of body lift.
by ErikSS » Tue Apr 05, 2016 8:27 pm
