offroadTB.com • View topic - Heavy Duty tie Rod's.
by Jrgunn5150 » Wed Jan 27, 2016 10:43 pm
IDK if you guy's have seen these, I found them browsing the Hummer forums. Looks like he makes them to order, I know some of you have had failures.
http://bulletproofsteering.com/gmifstierod.html
by Chris68chevy » Wed Jan 27, 2016 10:59 pm
Looks like a solid solution if he could change out how the they connect to the rack and pinion on our platform. I know several were talking about fabtech tie rods when the 2500 tie rod mod was started, and a member found out that they wouldn't fit into our rack and pinion. I might be worth someone messaging him to see what he can do for us.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Chris68chevy
by Jrgunn5150 » Wed Jan 27, 2016 11:03 pm
by Jrgunn5150 » Wed Jan 27, 2016 11:04 pm
All the different options he has are here, http://bulletproofsteering.com/gmpricingoptions.html , it was a bit tricky to navigate that site lol.
by Chris68chevy » Wed Jan 27, 2016 11:18 pm
Chris68chevy
by Jrgunn5150 » Wed Jan 27, 2016 11:47 pm
by TBYODA » Thu Jan 28, 2016 9:16 pm
Beefing up the tre's have been talked about before and one thing your not taking in to consideration is were those forces will go if the tre's are stronger like those in the link. Most veteran members and us engineers believe that it is possible to blow out the rack with something stronger than the 2500hd mod and rough country sleeve. Basically the stock and 2500hd tre's are a mechanical fuse. I hate to blow apart my rack in the back country.
by Jrgunn5150 » Thu Jan 28, 2016 9:27 pm
There's actually some pics of that's guy's tie rod's bending like a noodle lol. So IDK that I'd do it anyway.
