Lift question
by earlstb » Fri Nov 27, 2015 11:34 pm
Okay I got the front done!!!! Wew!! Then I moved to the back. I am using a lift at work so I got the body supported and undone the top shock bolt and lowered the rear axle but I couldn't get the springs out?!?! What am I missing? I even undone the rear sway bar links still not enough to get the springs out. Help please
901
earlstb
Vehicle Year: 2009
by KingBird » Fri Nov 27, 2015 11:35 pm
Are you using a spring compressor?
KingBird
by v7guy » Fri Nov 27, 2015 11:40 pm
It's been a good long while, but if the shocks and swaybar isn't holding it up the only thing left is brake lines and e brake cables. The springs should basically just fall out.
by DirtyBacon04 » Sat Nov 28, 2015 6:50 am
either use a spring compressor (shouldn't need much) or even bottle jack to push the axle a lil further down. I think I just used a pry par to get mine out.
by earlstb » Sat Nov 28, 2015 4:15 pm
I had spring compressors but the bolt bowed so they aren't straight anymore. And I was thinking the about the brake lines too
901
earlstb
Vehicle Year: 2009
by earlstb » Sat Nov 28, 2015 4:16 pm
What about getting the spring back in with a pry bar??
901
earlstb
Vehicle Year: 2009
by DirtyBacon04 » Sat Nov 28, 2015 6:10 pm
I think I used it to get it back in too... it's been so long.
by earlstb » Sat Nov 28, 2015 9:29 pm
Thanks dirty
901
earlstb
Vehicle Year: 2009
by earlstb » Sat Nov 28, 2015 9:31 pm
My buddy had a hydraulic one at his work he used after my busted
901
earlstb
Vehicle Year: 2009
by ErikSS » Sun Nov 29, 2015 12:03 am
Mine came loose pretty easy as Jason said. I did the bottom shock bolts and the passenger side sway bar link. Are you sure the shocks aren't holding it up?
by earlstb » Sun Nov 29, 2015 12:20 am
Mine**** I can speak English lol
Yea I undone the top of the shocks. Took the bolt completely out but never undid the Panhard bar the brake lines were tight no slack
901
earlstb
Vehicle Year: 2009
