by v7guy » Sun Jun 29, 2014 11:09 am
If you leave the shock yoke loose when you go to install the assembly you can spin the shock yoke on the shock to be inline. From there you can torque the shock yoke bolt. I generally compress the spring until the nut on the shock will easily thread on a few turns, then i tighten the nut and remove the spring compressors.
You'll also find that adding some washers to the shock shaft will help you get a little more down travel while helping to prevent topping out and ripping the threads off the shock.
