Z71 Spring Install Question
by whiplash » Sat Oct 06, 2012 2:12 am
Is there a right and wrong direction to install the Z71 spring? I searched and some are installed with the blue bumper on top and others on the bottom.
whiplash
by v7guy » Sat Oct 06, 2012 6:11 am
All the springs I've seen have a sticker that says "frame". That side goes towards the frame.
Or you can put the blue side up if its missing the sticker.
by The Roadie » Sat Oct 06, 2012 12:11 pm
I never understood any technical reason for claimed directionality of springs. JD?
by Moots1288 » Sat Oct 06, 2012 12:22 pm
One side of the spring has thicker coils that goes on the axle and the blue side goes on the frame as v7guy said
by The Roadie » Sat Oct 06, 2012 12:44 pm
Assuming the spring perches are identical and the coil end treatment is the same.
by 06MidnightBlue » Sat Oct 06, 2012 1:31 pm
I ran my Z71's both ways for shits and gigs. Never had a problem either way.
06MidnightBlue
by whiplash » Sat Oct 06, 2012 2:06 pm
Thanks guys! I installed them incorrectly and wanted to make sure i was alright driving around until i can get under there and flip them.
I walked out to the car this morning to admire the lift and noticed the frame sticker (after v7guy pointed this out). :wallbash:
whiplash
by v7guy » Sun Oct 07, 2012 1:33 am
I don't know with certainty that it will cause problems, but Moots springs collapsed while installed upside down in well under a year. He doesn't haul much at all. Mine are installed correctly and I load gobs of weight/stuff in the truck and haven't had a problem and they have been in for a year. Maybe Moots got lucky and got a bum pair. Maybe not.
by whiplash » Sun Oct 07, 2012 1:41 am
v7guy wrote:I don't know with certainty that it will cause problems, but Moots springs collapsed while installed upside down in well under a year. He doesn't haul much at all. Mine are installed correctly and I load gobs of weight/stuff in the truck and haven't had a problem and they have been in for a year. Maybe Moots got lucky and got a bum pair. Maybe not.
Thanks for the heads up. I was able to flip them today.
whiplash
