by Mudwheelin » Tue May 15, 2012 12:31 am
Wow, you really need to use the search bar. Go with the markmc 2.5" lift. That's what I've had on for a year now and don't have any complaints about it. It comes with everything you need. But you will need tools such as...pickle fork, spring compressor, pitman arm puller and a good pry bar. All the lift kits come with instuctions on how to install. If you have never been into this stuff have you taken into consideration that your going to be replacing parts often? You go through tires faster(atleast in my case you do...). There's a lot more to lifting a a vehicle then just "lifting a vehicle". I would say you need to do alittle more research. This forum has everything covered multiple times. If you get stumped then ask questions...but don't ask if you haven't searched for it first.
Build Thread:
viewtopic.php?f=25&t=2349
