About to purchase. Critique my setup
by Dirtyd » Wed Apr 11, 2012 12:09 am
I am totally new to the truck world, lifts, wheels and so on. I have done lots of research and have come up with a pretty good idea of what I want. But, before I make the big purchase I want to make sure I'm not missing anything or that my setup will look completely ridiculous.
I will be towing my boat and ATV all summer on trips no more than 300 miles. In the winter I will be towing my ice house and ATV about the same. I plan on offroading the TB quite often but on nothing to crazy.
My TB is an 08 with 60k
Here is the setup I plan on buying:
MarkMc 3" Suspension lift
HD Bilsteins in front
BDS 5500 Rear
Z71 springs
Wheels - Cragar Soft 8's 16x8 4.5 backspacing with 6x5 to 6x5.5 1.5" adapters
Tires- This is where I need help... I don't want anything bigger than 33" and don't want crazy poke on them, just something that looks "right."
THANKS FOR ANY HELP!!
:flex dirty:
You Only Live Once
Dirtyd
by djthumper » Wed Apr 11, 2012 12:54 am
First couple of questions... What rear end do you have? Do you plan on doing a body lift with the lift? If not you can pretty much rule out the 33s
by Dirtyd » Wed Apr 11, 2012 12:58 am
To be honest I have no idea what rear end is in it. Its obviously 4x4 and I would have to check out what rear end I have tomorrow. I don't want a body lift. 33" was the max, I'm totally cool with 31,32".
You Only Live Once
Dirtyd
by Dirtyd » Wed Apr 11, 2012 1:06 am
Stupid question. I remember seeing somewhere how to tell what rear end you have and can't remember where. How do I know? sorry for being so noob
You Only Live Once
Dirtyd
by Dirtyd » Wed Apr 11, 2012 1:22 am
okay, I have the gu6 3.42.. The things I will be towing are no more than 3000lbs
You Only Live Once
Dirtyd
by Me007gold » Wed Apr 11, 2012 7:08 am
Tires go with 265/75/16, right about 32" fills the wheel wells nicely and should only require a bit of trimming of the fender liner, depending on tire style
Me007gold
by Flying Monkey » Wed Apr 11, 2012 9:06 am
I run 33's without a body lift. Had to do a little trimming but nothing major. Same wheels. You can look in my build thread to see what trimming I did.
Flying Monkey
by Trail X » Wed Apr 11, 2012 12:15 pm
When you go above 32s, you can do it with no body lift, but you've got to be smarter about it. Skinnier tires, less backspacing... or... just cut the crap out of things.
by Gordinho80 » Wed Apr 11, 2012 12:26 pm
285/75/16 (33's) with BDS suspension lift, 88 fronts, z71 rears... I rub, haven't tracked down where it rubs yet... but there is rubbage.
by Dirtyd » Wed Apr 11, 2012 12:51 pm
Thanks for the help everyone!
My biggest concern is having crazy poke, I don't want the tires sticking out abnormally far.
With the 16x8's with 4.5 backspacing and 265/75/16 will that sit right or poke out to much?
Thanks
You Only Live Once
Dirtyd
by DirtyBacon04 » Wed Apr 11, 2012 5:37 pm
djthumper wrote:First couple of questions... What rear end do you have? Do you plan on doing a body lift with the lift? If not you can pretty much rule out the 33s
I'm rollin on a 2" lift all around, z71s, and 89s up front. And the only thing I had to do was trim up my fenders.
As far as the OP is going. You have a good handle on what you need. the setup you've chosen is a very popular one. As far as tires go, BFGs might be what you're lookin for. You're doin well with your approach, so just do the same research for tires as you did for everything else. Don't worry about having what everyone else has or trying to impress us. Just do your research and get whats best for you. We will stop you (or at least warn) if you're about to do something dumb, but aside from that, keep on keepin on brother. Good work!
by Dirtyd » Wed Apr 11, 2012 11:53 pm
Okay, my final question is
What backspacing do I need with 1.5 adapters with 265/75/16's
I hate crazy poke, want something flush or a tad bit more than flush.
You Only Live Once
Dirtyd
by Dirtyd » Wed Apr 11, 2012 11:56 pm
should I get 16x8 with 5" backspacing or 16x7 with 4" backspacing
You Only Live Once
Dirtyd
by Trail X » Thu Apr 12, 2012 9:19 am
We can't answer that for you, as there isn't a 'correct' answer.
Do the math yourself, and you can figure out where your new rim will reside.
1.5" adapter = 1.5" more sticking out.
4" backspacing = 2" more sticking out. (stock is 6" backspacing)
8" rim width = 1" more sticking out. (stock is 7" rim width)
So what you laid out will stick out 4.5" more than stock.
by The Roadie » Thu Apr 12, 2012 11:23 am
Dirtyd wrote:I hate crazy poke, want something flush or a tad bit more than flush.
That's a huge limitation if your mission demands certain size tires or tread patterns. If you've already defined "appearance" to be high on your list of goals, then that's going to force compromise on other things. As soon as you want a tire larger than the steering knuckle design will allow to tuck under the upper ball joint, it's going to (by definition) be sticking out at least 2"+. Are you really intending to go on trails where people are going to disapprove of tires that stick out? :safari: Or don't you have those sort of trails available?
by DirtyBacon04 » Thu Apr 12, 2012 6:00 pm
you want flush or almost, go with a stock rim. Typically any GMC, Chevy, or Tundra truck rim will fit. My rims came off a Silverado and I dont even need fender flares (legally).
by boog2006 » Thu Apr 12, 2012 6:22 pm
DirtyBacon04 wrote:you want flush or almost, go with a stock rim. Typically any GMC, Chevy, or Tundra truck rim will fit. My rims came off a Silverado and I dont even need fender flares (legally).
Your still running a spacer/adapter right?
Boog2006 Build Thread
boog2006
by rjpoog1989 » Thu Apr 12, 2012 6:34 pm
You would have to use an adapter to fit silverado rims. They have a different bolt pattern. Also, you need an adapter to go above 30 inches.
Ryan
Rule #76: "No excuses, play like a champion"
rjpoog1989
by DirtyBacon04 » Thu Apr 12, 2012 7:32 pm
correct. I have the MotorSport Tech 1.5" adapters.
by Dirtyd » Thu Apr 12, 2012 11:08 pm
Thanks for the help once again. DirtyBacon whats the backspacing on the Silverado wheels?
You Only Live Once
Dirtyd
