So i'm finally getting around to getting funds for my lift, and im not trying to build my truck into anything for rock crawling or mudding, but i want to get as much usable lift as i can andmore ground clearance.
On my uncles farm, we have gone through a company for custom springs for some of our farm equipment, all leaf springs though. Now i dont know a whole lot about them besides the fact that we keep going back to them. I want to find out if they can for coil springs and how much they will be. Long back story but heres the goods.
I did some research on the OS and found a post that the roadie posted: http://forums.trailvoy.com/showthread.php?t=52217
So the springs im basing them on are (spring rate/check load/free length)
Front 70 n/mm / 8988 n / 408.3 mm
Rear 41.9 n/mm / 4692 n / 409 mm
I plan on going with the stiffer suspension so im getting some lift there judging by the informaton in this post viewtopic.php?f=15&t=158 but i want a little more so i was planning on adding about an inch and three quarters (45mm) to the free length of both the front and read springs and make them both 455mm long.
So here it is. Im not a fancy engineer and i dont know a whole lot about this kind of stuff, so should this be about right? I think (emphasis on think) this should give me just under 3 inches of usable lift. Let me know what you think and what i did wrong.
And if they dont do custom coil springs? Ill be talking to mark soon....
XJ Cherokee springs are VERY close to ours.. they might even work on the tb... I got bored one day and decided to see if my old trailblazer springs would lift my cherokee, and they were very close to fitting. If the inside diameter of the tb spring was about 1/4" larger it would have fit onto the xjs coil bucket.. With a little hammering it probably would have fit, I just wanted to be able to get the spring back off one day so I didnt do it lol
