JamesDowning wrote:What's the downward limiting element?
MrSmithsTB wrote:Compressors FTW. What I did was put the Z71 spring in by itself and jack up the rear to compress it. I then snugged the compressors on and let the jack back down, shoved in the spacer, jacked the rear back up, loosened the compressors, and repeated for the other side. Your brake line could also be running out of slack.
HARDTRAILZ wrote:I just disco'ed the sway, unhooked shocks, and pushed the spring up and they slipped in...well they are in, wasnt easy but doable...
DJones wrote:When Regulator and I put my lift on (without Z71's) a hydraulic floor jack turned out to make it the easiest to put the spacer in. There was plenty of leftover room, but I have no idea how much longer they are when uncompressed.
Rob93 wrote:Got them in... too dark for pics right now
But the rear rides STIFF, i feel like i'm topping out the shock over every bump... I think I'm just going to order the bds shocks now, because I was planning to do it once I got all the lift on, but this is too stiff lol
fishsticks wrote:Rob93 wrote:Got them in... too dark for pics right now
I had the same problem.... BDS shocks made it all go away.
irishboy02 wrote:Love my 9500s.
On BDS site they have a dealer locations place where you can put in your zip and they can help you out with that. Otherwise, you can order direct from them IIRC
Rob93 wrote:Also: where are you guys ordering them from? straight from BDS? Or this there someone cheaper.... I'm going with the 5500s btw
Zero wrote:Its funny that Irishboy and I are both named BRENDAN, spell it the same way, and are both Irish hahahaha
