HARDTRAILZ wrote:......
He said removing the tires...it has to sit on something then and jack stands are probably the best bet.
No. The body isn't really twisted that much to throw the holes off, seeing the other side is still together for the most part.Opeth wrote:So when you jack up the one side to install the blocks, doesn't this cause the bolts to become misaligned with the holes? I guess I might be over thinking this, but wouldn't the bolt be like .../.... That since one side is higher than the other?
People putting on body lifts typically have something more functional than a brush guard up front.hobbstisdaman wrote:Has anyone relocated the brush guard after the body lift?
(Obligatory snark...)
Opeth wrote:So I think I am missing something here.... I have 12 blocks in my kit, im only seeing 10 body bolts/block locations. 3 under the doors on both aides, 2 in the rear and 2 more up near the the radiator. Where are the other 2?
Nvm......brain fart this morning while spraying everything with PB blaster.
