If you find yourself topping out the shock too often, then cutting the end of the spring will give you a lower resting height, so you have more downward articulation to soak up bumps.
Randy, I think we are miscommunicating the "down" word (as it can be a bit ambiguous).
I was referring to it as "if you wish to bring your resting height down relative to the ground".
I think you may be referring to it as "if you wish to bring your max down articulaton down relative to the body".
Agreed, but how is the stiffer spring going to change the ability of the cv to turn when full downward travel will not change from one spring to another?
It shouldn't, where did you get that?
