HARDTRAILZ wrote:Is it bad that I left a guy a message on a 4.09 geared D44 last night?
Out of what? I have an extra 44. Too bad you are not closer.
OregTrailBlazin wrote:fishsticks wrote:A couple interesting things: First off, the Suspensionmaxx "1/2 inch" shims are actually only 3/8" thick.Secondly, my UHMW, which I thought was only 3/8" thick, is actually 7/16" thick. Stacking it nets 7/8 instead of the original 3/4 I thought I'd get.
ried to move the motor when I turned the wheel by hand. No go.
You guys realize that the thickness of the spacer it self does not correlate to the amount of lift you will get....Right? A thinner spacer like a 3/8" will net about a 1/2"-5/8" on our truck. The strut is mounted closer to the pivot point on the lower control arm, so a little bit of movement there, is more exaggerated at the tire....
MrSmithsTB wrote:I hope everyone is aware of that. Also, I feel bad talking about all of this spacer speculation in a thread that was supposed to highlight our ability to reverse the UCAs. That idea is awesome, but hopefully it doesn't get dragged down by all of this negative lift info.
This thread has been hi-jacked like no other... I'm not even sure where to begin to clean this up...
HARDTRAILZ wrote:
You know we have about 66 inches from mounting surface to mounting surface from what regulator measured for me. 61 would have been pretty narrow
