offroadTB.com • View topic - Reversing UCA's (Pics)
by fishsticks » Wed Aug 18, 2010 1:47 pm
The old Trailblazer -
by Trail X » Wed Aug 18, 2010 1:51 pm
by fishsticks » Wed Aug 18, 2010 2:01 pm
by Trail X » Wed Aug 18, 2010 2:08 pm
by fishsticks » Wed Aug 18, 2010 2:15 pm
by Trail X » Wed Aug 18, 2010 2:25 pm
by fishsticks » Wed Aug 18, 2010 3:23 pm
by Trail X » Wed Aug 18, 2010 3:38 pm
by fishsticks » Wed Aug 18, 2010 3:51 pm
by Trail X » Wed Aug 18, 2010 4:15 pm
Mcmaster # 87235K122 is a polyurethane sleeve that should work well to cut to a desired thickness. It's a 6" sleeve.
I believe it's the proper Durometer spec - 60A?
They have a harder spec - 80A. That's Mcmaster # 87235K123.
by fishsticks » Wed Aug 18, 2010 4:26 pm
by Regulator1175 » Thu Aug 19, 2010 2:02 am
by The Roadie » Thu Aug 19, 2010 11:08 am
by djthumper » Thu Aug 19, 2010 12:21 pm
Thank you Professor Roadie. ;) When I first read his statement last night I was wondering how they were connected to a pitman arm and figured I was just too tired. hehe
by Regulator1175 » Thu Aug 19, 2010 12:57 pm
by fishsticks » Fri Aug 20, 2010 3:05 am
Since my parts came in a day early and I decided to do my front disconnect today, I did my 88 springs as well.
I jacked my truck up and let the front wheels hang. As I've said before my driver's side tripod was binding at full droop... enough to move the motor on it's mounts it turns out. :awesome:
So I put the jack under my driver side control arm. I alternately jacked up the wheel and spun the tire until there was no binding on my tripod. When I started my hub-fender was 24.75". At ~24.5" I had zero binding issues. So I figured taking 3/16" (3/16" x 1.5 = just over .28") out of my strut assembly length would put me in the clear.
I bought a bunch of 3/8" grade 8 washers a few days ago in preparation this project. My plan has been to remove the 7/8" from my top spacers completely, letting the new springs handle my resting lift. So when I had my struts apart, I added 9 washers to each side (9 washers ended up being ~21/32") of the strut rod. 3/8" washers fit just a hair more snugly than 10mm washers.
My bushings were only about 3/8" think and compressed fairly easily. I was able to get the nuts back onto my struts and tighten them down so that the top was past the keyed portion of the shaft.
I reinstalled the assemblies without my top shims.
By the time the struts and front disconnect were done and installed it was dark so if anyone wants pics I can take them tomorrow. I gained .5" of resting height from this setup over my previous multi-shim setup. I drove it around the block to settle the suspension and then measured. I went from 38" to 38.5" ground-fender. At full droop I am ~24.5" hub-fender. I have just a hair of resistance on the driver's side tripod, but it's so slight I'm not going to diassemble the strut just to pull one washer.
So now I have .5" of negative rake. I either need to unload some stuff from the back (unlikely), add some lift to the rear (probable) or add some weight to the front (hmmmmmmm).
by HARDTRAILZ » Fri Aug 20, 2010 11:24 am
Have you or anyone who has flipped got the camber corrected? I think I am going to flip mine back since it will help alignment and i already removed some of the lift. It rode too rough for everyday driving with everything maxxed out. I still think the right set of 35s is do-able though.
by Trail X » Fri Aug 20, 2010 11:30 am
Kyle, that rough ride is due to the shock bottoming out... the only way to fix that would be to cut down your inside spacer, or add shims like Fishy did.
by DZPearl » Fri Aug 20, 2010 12:06 pm
Now wee just need to talk the shock companies into making a front replacement with a 3/4"-1" longer shaft to accomodate the longer coil spring while lowering the tension to make a ride that is not too firm for everyday driving. Or, have a shaft extension machined to fit.
DZPearl
DriveTrain: 2WD w/ G80
by fishsticks » Fri Aug 20, 2010 12:18 pm
