offroadTB.com • View topic - RadFlo Group Buy
RadFlo Group Buy
by Trail X » Mon Nov 04, 2013 4:42 pm
Kyle, if it makes you feel any better, I'm looking forward to getting exactly what Matt has. That thing kicked some butt during my 5 minute test drive. I think the 600 lb spring rate was right on, as it seemed spongy enough to absorb bumps, but it didn't allow the truck to continue downward after a bump so far that it bottomed out the suspension - like my 87s do.
I'm looking forward to taking the water breaks on the trails at full speed and getting some air with the front tires without fear of constantly bottoming out the suspension. I'll probably get straps for the rear though, since the rear shocks don't have the same construction as the fronts. Don't the Radflos have internal extension bump-stops built in?
by HARDTRAILZ » Mon Nov 04, 2013 4:46 pm
That's interesting since he was talking about getting softer springs.
I was debating straps in rear already but need to test regulators brake line extention idea before doing anything.
by ErikSS » Mon Nov 04, 2013 5:03 pm
I found the rear of Moots truck to be too soft. Maybe that changed JDs opinion a bit.
by Moots1288 » Mon Nov 04, 2013 5:10 pm
by OregTrailBlazin » Mon Nov 04, 2013 6:04 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by ErikSS » Mon Nov 04, 2013 6:49 pm
Holy Crap! 30 stiches in the palm of your hand?!?!? Obviously your "ok" but I hope you get better fast. Oh... And Were Are My Coilovers?!?!? Haha
by HARDTRAILZ » Mon Nov 04, 2013 7:00 pm
Damn. Hope it all heals well and quick!
by AlekG » Mon Nov 04, 2013 10:37 pm
Just a couple of slightly related comments from a VERY early adopter of coilovers ...
When I jumped in, I had to take a huge leap of faith in the FabTech DirtLogic 2.5 coilovers. As you may suspect, they were not being very helpful as I believe they were weary of any kind of custom use of the set I decided on - they are for Toyota Tacoma's and are adjustable 0" - 3.5". There is no mention of spring rate anywhere but I decided to go with the Tacoma ones vs the Tundra ones as I thought they would be a better match for our vehicles (the Tundra being a full size pickup). The full kit for the Tacoma also doesn't come with any limiting straps as I believe the design itself and the sturdiness of the constructions limits the travel as required.
How could I be sure of the measurements? Well, believe it or not, I took this diagram which they had in high-res on their site:
and using the known 2.5" diameter of the shock, I extrapolated all the other measurements that I thought were pertinent to get a handle on the top plate sizing, clearance needed for the spring, overall length, etc. etc. The big chance was relying on my shop to find a solution for the bottom mounting ... which they did.
In the long run they served me extremely well over many, MANY, miles on-road and off-road. As for the spring breaking a couple of years ago, my mechanic believes it was not through any stress related issues, but perhaps a stray rock knicked the metal enough to cause a stress fracture in the spring steel which ultimately gave way ... luckily not very far from home.
The good news is that the new springs are in and they are performing as good as when I bought them. I cleaned the shocks up with a Dremel soft brush and gave the stainless areas (not including the piston rod) a coat of clear flat rust paint. I wish I had the foresight of doing that when I first got them.
I think overall everybody is going to be very happy with the RadFlo's in terms of performance. I hope they are as robust as my experience with the FabTech's. All the tweaking that is potentially available to you guys is really a bonus.
(old picture, before the spring break)
AlekG
by ErikSS » Mon Nov 04, 2013 10:45 pm
I really like your truck. Why don't you have a build thread? I'm surprised you don't have your upper control arms flipped.
by Moots1288 » Mon Nov 04, 2013 11:16 pm
This is around 2 - 2 1/2 inches of lift
by v7guy » Tue Nov 05, 2013 6:12 am
If you wanted to try out different spring rates for the different setups we all run it would be pretty easy to get a spring rate with the online calculators available such as here
http://www.crawlpedia.com/spring_rate_calculator.htm
http://www.hypercoils.com/spring-rate-calculator/
The biggest problem is finding a place to get your corner weights from. I believe Rory said he got his vehicle weight (around 6000 lbs loaded, he didn't state the corner weights if I remember right though) from work, but for most of us it'll be tougher to find a place to do it at.
As far as unsprung weight, I can weigh a spindle,control arms, caliper, rotor, if it'll help someone, they're just laying in the garage. You'd have to add the weight of your specific wheel and tire.
From there, the rest is just measurements. Unfortunately I've committed these measurements to memory...
UCA length is 9"
LCA length is 15"
shock mount to LCA pivot is 10.5"
strut angle is about 75 deg
the useable wheel travel will depend on your combo, but again, not difficult to measure. The only real problem I see is that the radflos should add some useable wheel travel since it's a smaller diameter than the stock setup.
by jonbo2002 » Tue Nov 05, 2013 7:12 am
jonbo2002
by AlekG » Tue Nov 05, 2013 7:16 am
AlekG
by OregTrailBlazin » Tue Nov 05, 2013 2:01 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by DirtyBacon04 » Wed Nov 06, 2013 4:08 pm
by ErikSS » Wed Nov 06, 2013 11:13 pm
by Trail X » Thu Nov 07, 2013 9:12 am
Back to the group buy. Did I miss a planned ship date? Do we know when to expect these? I've got a free weekend next weekend and would love to install these then.
by HARDTRAILZ » Thu Nov 07, 2013 9:18 am
That's opening weekend of deer season for me, so it won't work for me.
by mikekey » Thu Nov 07, 2013 12:16 pm
by HARDTRAILZ » Thu Nov 07, 2013 12:20 pm
They will make a great Christmas present to myself and give me time to figure out how to explain to the wife that I an getting them.
