by Moots1288 » Mon May 13, 2013 2:50 pm
TBYODA wrote:The 89 come up on gmpartsdirect.com but I am not sure if that means they are in stock or not .
I have a pair of 89s I am selling.
by v7guy » Mon May 13, 2013 3:35 pm
Last I knew they were still available.
You'll get a better deal grabbing em from Moots though.
by rgraboske » Mon May 13, 2013 4:34 pm
I bought 85s last month with no problem at all.
rgraboske
by rz03LTZ » Mon May 13, 2013 8:46 pm
I was in the Stealership 2 weeks ago and out of interest I asked if the could order me pair of 89s. The guy said they could get a set shipped in from somewhere in Michigan in a couple days.
rz03LTZ
by joe110010 » Tue Aug 27, 2013 12:41 pm
Left 6DF = 85
Right 7DC = 84
In call with dealer, the 87, 88 and 89s were available to be shipped to CA from MI on 4 days' notice.
Looking to go up to 87s - the price quoted was $76 each, 40 bucks cheaper than the 84's at $116.
So on right side, from an 84, that would be 14.6mm strut lift = .57 in. strut lift = .84 in. wheel lift. Sound right?
Thanks
joe110010
by Trail X » Tue Aug 27, 2013 12:47 pm
Wow, I haven't seen anyone with anything higher than 84s stock. Interesting.
Your numbers sound right overall, keep in mind it will probably look like more at first, and settle in as less later.
by mikepeters1983 » Tue Mar 04, 2014 10:47 am
So on a off note, when looking in my rpo codes for my xuv it says that I have 6ad, and 7ad, I have not be able to find them in the list anywhere at all.
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by mikepeters1983 » Tue Mar 04, 2014 10:54 am
Also on a note. I ran 89's for about 6 months while i had my ext trailblazer. they ran good, but there are some down falls in my opinion. It did support the add weight of all the armor and the winch, but also was breaking more things then I should of. in a 6 month span, i went through 3 struts on the front. 2 brand new wheel hubs, and in the end, i was driving down a back pave road with a spot for water to cross, well i hit it and got a little air, and i snapped off my passenger side diff. IMO 89s dont work well. its not that they are to stiff, but the force that they have is to mush and breaks things.
mikepeters1983
by TBYODA » Tue Mar 04, 2014 11:05 am
mikepeters1983 wrote:So on a off note, when looking in my rpo codes for my xuv it says that I have 6ad, and 7ad, I have not be able to find them in the list anywhere at all.
Are the Google search servers broken? Click below to check. :facepalm: :work:
GOOGLE IS YOUR FRIEND
GOOGLE IS YOUR FRIEND AGAIN
by mikepeters1983 » Tue Mar 04, 2014 11:11 am
Wow no there not broken, but was putting it up for more of a point of why are then not on the list, maybe we should or even could add them to the list. And the most of the only list
COMPONENT FRT RH COMPUTER SEL SUSP (7AD)
COMPONENT FRT LH COMPUTER SEL SUSP (6AD)
I know what to look for, this aint my first go arround, but that does not tell me what type of spring that I have in there.
mikepeters1983
by TBYODA » Tue Mar 04, 2014 11:48 am
mikepeters1983 wrote:Wow no there not broken, but was putting it up for more of a point of why are then not on the list, maybe we should or even could add them to the list. And the most of the only list
I know what to look for, this aint my first go around, but that does not tell me what type of spring that I have in there.
I am thinking you are going to have to go look for the tag on the spring because as stated in this post the springs where chosen during production and likely different side to side to level SUV.
by The Roadie » Tue Mar 04, 2014 1:24 pm
RPO codes do not always directly translate to part numbers. Juts like you can't walk into a GM dealer and walk out with a "G80".
by mikepeters1983 » Tue Mar 04, 2014 2:30 pm
I tried looking for the tags and I don't see any. It looks like the dealer might of even painted the underbody to make it look better.
Sent from my SM-N900T using Tapatalk
mikepeters1983
by djthumper » Tue Mar 04, 2014 3:35 pm
Maybe it will pull up is someone is able to do a VIN lookup for you.
by mikepeters1983 » Tue Mar 04, 2014 4:13 pm
I don't know. It's been a while since I have been on this site.
mikepeters1983
by jonbo2002 » Tue Mar 04, 2014 9:44 pm
you can pm me your VIN but I believe a VIN decode will just bring up the same numbers you came up with. I'll give it a shot though
jonbo2002
by mikepeters1983 » Fri Mar 07, 2014 7:57 am
So no luck with the vin look up, looks like I might have to try looking again on the springs and see what I find, if I can find something
mikepeters1983
by nvrs » Sun Mar 23, 2014 11:53 pm
Maybe I am reading this wrong but the chart here;
Seems that the 15125881 is stiffer than 15125889?
Is this correct?
nvrs
by TBYODA » Mon Mar 24, 2014 12:04 am
nvrs wrote:Maybe I am reading this wrong but the chart here;
Is this correct?
Other way around I believe you miss this in the post "A higher spring number WILL produce a stiffer, rougher ride." :read: http://forums.offroadtb.com/viewtopic.php?f=15&t=158
by nvrs » Mon Mar 24, 2014 12:10 am
Thanks...
nvrs
