Front Fender Well Mod
by Lauron » Tue Sep 25, 2012 10:42 pm
Clearance is between 1/2 to 1". Haven't measured it but no rubbing. With some hard wheeling I could see it might rub but bushing are tight, so we will see. The lower edge of the moulding will touch first which I can cut back and remove the bolt if necessary.
Mudwheelin and I are going to test things out on the trail some time soon.
Lauron
by fishsticks » Tue Sep 25, 2012 11:18 pm
Lauron wrote:Clearance is between 1/2 to 1". Haven't measured it but no rubbing. With some hard wheeling I could see it might rub but bushing are tight, so we will see. The lower edge of the moulding will touch first which I can cut back and remove the bolt if necessary.
:thumright:
