JamesDowning wrote:There have been a couple reports of the RC lift failing. Not Fishy's though. Dmccartney I think...
I thought he only had trouble with one, twice.JamesDowning wrote:Didn't he break both of them? Going from recollection here.
fishsticks wrote:Good grief.
BDS uses white body shocks, most likely made by Gabriel.
So does Pro Comp.
So does SkyJacker.
So does Rancho.
So does Superlift.
My BDS shocks seep a little bit around the seals. The eye bushings in them are also about 1/4" bigger than they should be now. Why?
If you guys want to debate high-end shocks, that's fine. But the bashing of quality on a "bare minimum to make it work" product is lame.
I know that MarkMc 2.5" has failed 3 times (from what I read on TV)
Cable810 wrote:I'm really looking for something that replaces the facotry strut mount. Mark has his 3" that replaces it but I don't want 3" and I could get RC for cheaper... I know that MarkMc 2.5" has failed 3 times (from what I read on TV) Would there be any concerns with a used lift that I should be aware of?
djthumper wrote:Cable810 wrote:I'm really looking for something that replaces the facotry strut mount. Mark has his 3" that replaces it but I don't want 3" and I could get RC for cheaper... I know that MarkMc 2.5" has failed 3 times (from what I read on TV) Would there be any concerns with a used lift that I should be aware of?
The failures were from the original strut mount being dried out. Make sure you know what you are saying before you make a comment on it, and provide links to it.
fishsticks wrote:If he's looking to use 89 springs later he is on the right track IMO. I highly doubt the stock spring mounts will put up with 89s for long and 3" is too much to combine with them.
