Wow, you guys are all over the place! I like the enthusiasm! Lets see if I can hit some of the main points.
fishsticks wrote:Two concerns:
1. Will lengthening just the shaft of the strut cause the strut to excessively bottom out under compression?
2. Should we be looking at sourcing longer springs to compliment this, instead of stiffer springs with the same uncompressed height
1. Interesting observation, but we currently have that scenario because we never lengthened the stock bumpstop. I beleive this is why many of us are seeing spring sag - over-compression of the springs brings them into a yield stress zone.
2. Longer springs would have the same issue as the stock springs when over-compressed. It's all about adjusting the internal bump stop along with the lift.
Regulator1175 wrote:Those shock extensions would have made life so much easier when installing the heavier springs on Kyle's truck last week. It was a huge pain in the a** to get them compressed enough to get the upper mounts re-installed.
I believe it, you're cramming a very heavy spring into a very small area (due to the inside-the-spacer lift puck).
tbangert wrote:I understand what you are trying to do, but is this actually safe to do? I mean sure you will be biting quite a few threads, but quality of material used in those extenders would be my main concern.
I agree that there are material concerns. My idea was/is a homemade version of what you saw linked before. It should theoretically surpass the strength of the shock piston rod.
Philberto wrote:I would personally just look into making a mount or finding another aftermarket shock for another application that'd allow us a longer spring/shock assembly. I don't see why you'd mod the assembly when you can just substitute in another shock/spring combo.
Sure, ideally that'd be great, but you're completely changing the game now and making it hugely complicated. I'm going for simple and robust here.
fishsticks wrote:A puck that fit into our existing lower mount with a provision to firmly mount another type of strut would accomplish that.
Think Roadie's Icons except with the body pointing down instead of the shaft.
So you need to draw up this puck idea and have a machine shop turn it for you! Again though, you're only making things more complicated... your new shock now must withstand the same loads that our stock design handles - have a spring perch at the same location - and be compatible to mount to our upper perch. Unless you're willing to change the whole strut, I fear you're looking for a miracle.
MrSmithsTB wrote:Understandable concerns, but what would stop anybody from strengthening it when adding the length? Any concerns of integrity could be remedied with more structural support that is very easily added once the modifying is started. I would trust that before trusting strut extensions.
Why not just modify the stock lower strut mount?
Still, however, you're not accomplishing the goal here. The goal here is to be able to better accommodate the heavier springs for lift as opposed to just adding spacer pucks. Your proposition of cutting, lengthening, and rewelding the lower shock dogleg is far more complicated than adding pucks, but serves the same purpose. Sounds like a lot of work with minimal return.
fishsticks wrote:Strut extensions don't bear the entire weight of the front end. The lowers do.
Very valid point - the loads on the top of the shock piston, while high, are nowhere near the loads on the lower shock mount. Modifying the lower shock mount is just asking for trouble.
Lengthening the upper shock shaft with the right components along with a heavier spring would solve a few problems at once. Allow higher front weight capacities (winch, etc), decrease the frame slamming when on rocky terrain (due to the soft stock springs), and allow us to reach higher articulation levels with more inside the strut lift (ie springs in this case).
Maybe this helps to clear up where I was headed with the original inquiry... I was going to keep it to myself, but you guys are just too darn good at reading minds and taking an idea and running with it.
I still haven't gotten what I set out for... upper shock thread and shoulder dimensions.
