Just a lift kit?
by tlslayTB » Sun Oct 28, 2012 4:09 pm
Planning on getting the 2" suspension lift by RC for my TB.
Do I have to get different springs, etc. after the lift? Or can I just lift it without having to get any other parts.
I know that it really depends on what kind of off roading I will be doing. I don't plan on anything more serious than hunting trails with a few mud holes (2.5 max). Will the stock system work fine for me or are others springs and stuff recommended?
2005, 4WD, LS
tlslayTB
by The Roadie » Sun Oct 28, 2012 4:49 pm
That kit will do fine for what you need it to do. No change in springs is needed. What MOST folks do, since it's a lot of work to go into your struts and compress the beefy springs, is renew the shocks at the same time for $50-55 a side with new aftermarket Bilsteins.
by Cable810 » Sun Oct 28, 2012 5:42 pm
If he was to add a MDB Bumper I'd add some stiffer springs. But If you don't plan on a MDB Bumper don't upgrade the springs. There was a documented faluire due to running stiffer springs and no bumper.
I'd reccomend SkyJacker S97N8030 Rear Shocks. Get the Bilsteins as Roadie mentioned. I'd also suggest browsing Build Threads.
by ksmarshall » Sun Oct 28, 2012 7:35 pm
I just installed a 3'' kit this weekend and upgraded my skocks and struts while i had them apart , and I'm so happy that i did the truck drive so much better and rides closer to a fullsize , i would highly recomend it while your in it. i have a list of the parts i used and what i paied in the Build Threads under marshall is now lifted
2005 Trailblazer LS 4.2 L,4WD , 3'' Markmc lift, 1.5'' spacers, 265/75/16 Toyo AT2 -Wifeys ride
2004 Silverado ext cab, 5.3L 4WD K&N Intake, Bullydog Chip, 285/75/16 BFG All Terrains- My daily
1986 Chevy C-10 SWB, Built 355SBC ,700R4- The Hot Rod
ksmarshall
Name: Kyle Marshall a.k.a Marshall
by tlslayTB » Fri Nov 02, 2012 10:51 pm
Thanks so much for the good ideas and advice y'all! I'll have to do some soul searching and deciding to see what I need to do.
2005, 4WD, LS
tlslayTB
by v7guy » Sat Nov 03, 2012 2:00 am
The failure was due to running the stiffest springs available with no armor... that's an important clarification to make.
