best combo for 35s.
by navigator » Sun Feb 05, 2012 6:07 pm
the Fox 2.0 is the BDS 95 series replacement.
by MK-voy » Mon Feb 06, 2012 8:50 am
I know, sorry i didn't make my self clear the two # are for fox 2.0 but one is intended for trailblazer and envoy the other is for yukon and tahoe my question is did some one tried to fit the tahoe shocks offered by fox 2.0 on our platform???
MK-voy
by navigator » Mon Feb 06, 2012 9:12 am
I'm unsure what most are running, I would imagine the one for our platform.
Here is the BDS thread about it if you haven't found it.
viewtopic.php?f=33&t=2408
by djthumper » Mon Feb 06, 2012 10:28 am
The Fox 2.0 for our platform is already longer than stock.
by MK-voy » Mon Feb 06, 2012 10:49 am
but its built for 2 inch of lift where talking about 4 so it will be needing longer shocks, I think is that right ????
MK-voy
by MK-voy » Mon Feb 06, 2012 12:53 pm
where do i find top spacer smaxx or lif meister???
MK-voy
by navigator » Mon Feb 06, 2012 3:24 pm
so in Fishsticks build he has a rough country 2 inch lift + a top spacer from SMAXX + some washers installed between his strut and spacer as well as 88 springs.
Mark's new lift (The LiftMeister) is about 3 inches in the front. I would expect Mark's new lift is very similar in height to the suspension aspect of Fishsticks build(without the springs). I would also expect many here would agree it is close to the limit you can lift the suspension without adding heavy components like a winch/bumper and skid plates. Fishsticks has the stiffer 88 springs which are no longer available. They provide more lift but it is offset at least some by a winch bumper and skid plates. You might be able to go a little taller but you would very soon have CV binding when a wheel tries to turn at full droop.
I don't think you can use (or need) a top spacer if you get Mark's new lift.
Look up MarkMC in the vendor section and send him an email, he might be able to ship to you cheaper than other vendors. He is a great vendor to work with.
by plaen » Mon Feb 06, 2012 9:31 pm
navigator wrote:Look up MarkMC in the vendor section and send him an email, he might be able to ship to you cheaper than other vendors. He is a great vendor to work with.
Best bet would be to order through his site, now that its up and running.
theliftmeister.com
There is a contact form on there if you have questions, Mark is usually on the ball with emails, took all of 5 mins for me to get a response with the info I needed.
plaen
by MK-voy » Tue Feb 07, 2012 4:11 am
thank you guys for your help. :salut:
MK-voy
by MK-voy » Tue Feb 07, 2012 6:29 pm
does some one have pics for the same tb or envoy to compare the difference between 33 and 35 ?????
MK-voy
by HARDTRAILZ » Tue Feb 07, 2012 6:40 pm
Plenty of pics of mine w both. The black chrome rims have 33 and the white rims have 35.
by MK-voy » Tue Feb 07, 2012 6:44 pm
so HARDTRAILZ what do you prefer the 33 or 35 when ur wheeling???
MK-voy
by HARDTRAILZ » Tue Feb 07, 2012 6:51 pm
I never really wheeled the 35s just played at farm some. I did them more to see if it was possible since no one had. I have brand new 35s in the garage because I wanted the extra inch of ground clearance
by MK-voy » Tue Feb 07, 2012 7:06 pm
u ill be fitting the 35 soon and wheeling them???
MK-voy
