by bartonmd » Wed Mar 10, 2010 2:00 pm
I wouldn't run any higher than 35psi in tires on the TB... My stock tires I ran at 38PSI, and ended up at the wear bars in the centers, and 1/8" above the wear bars at the sides... I knew it would do it, but traded wear on crappy OEM tires for highway gas mileage when gas was $4/gallon and the wife was driving too and from STL weekly...
Optimum pressure is really dependant on the width of your tires (as well as side wall strength and tread thickness and tire thickness under the tread)... The wider they are, the less tire pressure you need... As a matter of reference, I'm getting good even wear on the current stock size Destination ATs at 32F, 31R empty (manual says 30F, 35R, but that's for rated load and towing, not running around empty)...
You really do have to experiment... With the TB, I can't see any kind of tire, stock width or wider, needing more than 35PSI, and I would expect that for stock width, but taller, and load range E...
This is empty... If you're loaded down or towing a heavy trailer, it should be bumped up some...
Whatever the load, your tires' sidewalls should bulge a bit on the part that's against the road...
bartonmd on Wed Mar 10, 2010 2:03 pm, edited 1 time in total.
