Mastercraft Tires 73226 - Mastercraft Courser MT Tires
by DmccartneyFF2TB » Sat Dec 18, 2010 9:55 pm
Brand Mastercraft Tires
Manufacturer's Part Number 73226
Part Type Tires
Product Line Mastercraft Courser MT Tires
Summit Racing Part Number MFT-73226
Tire Size 285/75-16
Wheel Diameter 16 in.
Sidewall Style Outline white letters
Tire Construction Radial
Directional No
Tire Diameter 33.10 in.
Section Width 11.30 in.
Tread Width 8.90 in.
Minimum Recommended Wheel Width 7.50 in.
Maximum Recommended Wheel Width 9.00 in.
Speed Rating N
Load Range D
Asymmetrical Tread Pattern No
Tread Depth 18.5/32 in.
DOT-Approved Yes
Tube Required No
Max Load Single (lbs) 3,305 lbs.
Quantity Sold individually.
(4.14 KiB) Downloaded 232 times
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by HARDTRAILZ » Sat Dec 18, 2010 10:11 pm
What about them?
by DmccartneyFF2TB » Sat Dec 18, 2010 10:15 pm
HARDTRAILZ wrote:What about them?
Worthy of being on a TB? :viking:
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by HARDTRAILZ » Sun Dec 19, 2010 9:15 am
Decent basic MT. Not sure if they are 2 or 3 ply sidewalls, but I would not get anything but 3. Also may not be be as good as some others if you really want a mostly trail rig like you mentioned in your other tire thread.
by DmccartneyFF2TB » Sun Dec 19, 2010 9:27 am
HARDTRAILZ wrote:Decent basic MT. Not sure if they are 2 or 3 ply sidewalls, but I would not get anything but 3. Also may not be be as good as some others if you really want a mostly trail rig like you mentioned in your other tire thread.
Anything you would suggest in a decient price? Like i stated in the other thread i want something 33/34ish.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by HARDTRAILZ » Sun Dec 19, 2010 9:41 am
What's decent? I feel 250 a piece was good for the peformance and value I have recieved from my pro comps. Should get 40,000 miles from them. Gobs of traction. Quiet. Great street manners. Tough triply sidewalls that have seen plenty of abuse. Nice lip for rim guard.
by DmccartneyFF2TB » Sun Dec 19, 2010 9:49 am
HARDTRAILZ wrote:What's decent? I feel 250 a piece was good for the peformance and value I have recieved from my pro comps. Should get 40,000 miles from them. Gobs of traction. Quiet. Great street manners. Tough triply sidewalls that have seen plenty of abuse. Nice lip for rim guard.
I did look at some procomps. I may go that way.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by fishsticks » Sun Dec 19, 2010 3:34 pm
33" version of what I run. E load rating, run fine at 15psi, clean out well and don't mind of you rub the sidewalls on everything you see.
http://www.discounttire.com/dtcs/tires/ ... 1&pc=11282
