16" wheels on a truck that came standard with 17" wheels???
by johnburgelin » Mon Jun 07, 2010 11:41 pm
I've got a 2003 chevy trailblazer LTZ, it came from the factory with the 17" alloy wheels, I'm thinking about getting 6x5 to 6x5.5 spacers and putting stock tahoe 16" wheels on it. But after looking closely at my wheels and the space between the caliper and the inside of the rim, it looks like it have barely anymore than a 1/2" of space at some places. That means that if i put the 16" wheels on they would pretty much be touching the calipers. Am I correct in assuming this? Do the 1.5" wheel spacers make a difference? I know that TB's came with 16" wheels stock but do the one's that came with 17" wheels have a larger disc and caliper diameter than the 16" ones?
Long story short, will 16" wheels fit on my 17" wheeled 2003 TB?
johnburgelin
by KE7WOX » Tue Jun 08, 2010 12:05 am
The EXT has larger brakes and you can't fit 17" wheels. I believe the same is true for the V8 (we can have that confirmed by those who know that better), but at least for the I6 you should have no issues fitting 16" wheels.
by Saxis » Tue Jun 08, 2010 1:05 am
My Denali definitely has the bigger calipers. I still have my stock 18x8s though, and going to 17x8s soon. I don't see any way there'd be room for 16s.
Saxis
by The Roadie » Tue Jun 08, 2010 1:17 am
SWB will fit the 16's just fine. Some 15's have been seen to work, but that's a LOT more dependent on the exact cross-section of the wheel.
by KE7WOX » Tue Jun 08, 2010 1:18 am
Isn't the Denali V8 powered?
by The Roadie » Tue Jun 08, 2010 1:24 am
Yes, and they aren't seen as much on the trails. I remembered from the OS that John has an I6.
by KE7WOX » Tue Jun 08, 2010 2:32 am
Yeah they're uncommon. IIRC, V8 powered trucks have larger brakes (same size as the EXT?) and won't allow for 16" wheels to be used. Am I correct?
But the OP has an I6
Hence or otherwise, he should have no issues fitting the 16" wheels
by johnburgelin » Tue Jun 08, 2010 4:23 pm
I do have the I6 4.2L and I just ordered my wheel spacers 1.5" from discussed in my other thread, and am picking up my 99 tahoe 16" wheels and 245/75R16 tires already mounted for $80 on saturday, hopefully next week or early the following my Z71 springs and markmc 2.5" lift will be here, as I just received my G80 yesterday.....seriously jumping in with both feet on this one
already got my cb mounted, air filter ordered, with plans to hog out the airbox, replace the resonator, and replace the exhaust resonator with a pipe as well.
johnburgelin
by johnburgelin » Tue Jun 08, 2010 4:24 pm
oh and thanks for remembering me from the OS roadie.....makes me feel a little bit special :)
johnburgelin
by Gordinho80 » Tue Jun 08, 2010 4:34 pm
Nice... sounds like you've got a good plan going. You clean up your build thread yet??? :poke: :slap:
by KE7WOX » Tue Jun 08, 2010 5:11 pm
Just a thing. Did you remember to get the spacers with the right bolt pattern (6x5 to 6x5.5)?
by johnburgelin » Tue Jun 08, 2010 9:02 pm
kind of cleaned up my build thread but I still have yet to delete the pics, I'll get around to it this weekend probably, but I did update my info. and yes i got the 6x5 to 6x5.5 adapters
johnburgelin
by irishboy02 » Thu Jun 10, 2010 4:49 pm
I have 15s that clear. Using them with 1.5" adapters to 6x5.5. Dont currently have them on though, waiting for tires. Rim has a BS of 3.75. My OEM are the 17"
Received my initial measurements from HARDTRAILZ and went from there. They do stick out of the fenders a wee bit though
2003 GMC Sierra z71
7" FTS lift
irishboy02
by HighSierraTB » Thu Sep 09, 2010 1:10 pm
This was the same question I've been wrestling with in putting together my mod list. I have a '06 LT V8 with 17" wheels. I'll have to measure the rear (and Front) calipers with the wheels off. I was hoping to get a second set of wheels/tires for trail use and didn't know if 16" would fit or not. I'll post my measurments when I'm done.
HighSierraTB
by HighSierraTB » Thu Sep 09, 2010 9:21 pm
Ok For my 2006 LT Trailblazer with a V8 and 17 inch Stock aluminum rims
Measurements:
In the front from the center of the hub to the outside edge of the brake caliper approx 7 3/4".
In the rear from the center of the hub to the outside edge of the brake caliper approx 7 1/2" inches
The gap between the inside edge of the rim (mounted) and the outside edge of the brake caliper was less than 1/2" in the front and about 3/4" in the rear.
I don't think the 1.5" wheel spacers will help much, but I don't have them, so I don't know for sure.
Conclusions: I can't use 16" rims on my truck. I'll just look into used 17" TB rims of the same style. I want to get a 5th one for the spare anyways. I don't think I want to go to 18" rims.
Hope this helps someone
HighSierraTB
by fishsticks » Thu Sep 09, 2010 10:17 pm
Doh. I could've answered your question earlier. Sorry I missed it.
EXTs and V8's have bigger front brakes. You need 17" wheels to accomodate those.
If you really wanted 16" wheels for wheeling you could acquire some I6 SWB front brake brackets and rotors. The calipers are the same. Then you'd clear 16" wheels.
I'll happily trade you. :)
