offroadTB.com • View topic - Lift/Tire Size Chart
by navigator » Tue Oct 25, 2011 1:51 pm
Tango, I don't see your build thread to add to the chart, can you PM me the link?
Monkey and Fuzz, I have updated the chart with your new tires.
I also split the chart into 2 parts, 15/16 inch wheels and 17+. James had already split out the folks with no builds.
Google docs doesn't like how big the chart was getting(to copy/paste) with it all in one chart so that is why I split them out.
Let me know if I flubbed anyone up.
by Flying Monkey » Tue Oct 25, 2011 2:03 pm
Not sure if its just a treadwright thing or not but the 285/75/16 guard dog is a
Outer Diameter: 33.2”
No big deal though. Just seen you have listed 32.83"
Flying Monkey
by navigator » Tue Oct 25, 2011 2:06 pm
thanks Chris, for the chart we are just posting the nominal size based on the math as all the tires run a little different in size. I think most folks realize that the Treadwrights run a little big.
Also, if I ever finish the build chart will have all the tire brands listed (if provided).
by v7guy » Wed Oct 26, 2011 8:05 am
by bigezzyk » Fri Oct 28, 2011 9:18 am
i have 245/70/17 and they are 30.8" i put them on with no lift and no wheel spacers they just fit on a stock envoy
bigezzyk
by navigator » Fri Oct 28, 2011 9:53 am
thanks Joe, if you want to put that info in your build thread I'll get you added to the chart.
by BSalty » Fri Dec 23, 2011 9:05 pm
Another update to my rubbing. I got it aligned after I replaced my tie rods a month ago, I now need sheet metal trim. It has rolled the top of my fender for me on both sides, and it is rubbing on the bottom rear of the fender pretty hard. Enough that I will definately be looking for an alterative mounting spot for the front bolt that holds the plastic rocker trim. It has rolled the tip of the fender already and will need to be cut back to stop the rubbing.
Formerly known as CBRguy.
BSalty
by ScarabEpic22 » Fri Dec 23, 2011 11:22 pm
Hi guys, I put a set of P265/70R16 Kumho Road Venture SAT KL61s on my 02. They clear the UCA just fine, have about 1/4" of room. I do have a 3" MarkMc new style lift, but honestly they'd fit at stock height too. They are 30.6" in diameter according to Kumho.
They're still P-tires, not LT. Fine for my use which is mostly highway with snow in the winter months, more of an all-around AT tire than an aggressive off roading tire. At $570 shipped from TireRack, they were one of the cheapest options and are performing on-par with the Bridgestone Dueler A/T Revos that came off and about the same as the Revo 2s I have on 17s that I run on my SS in the winter.
ScarabEpic22
by navigator » Sat Dec 24, 2011 5:11 pm
Thanks Brandon, that info should go in your build thread if it isn't already there, that is where the real value is.
Erik, your size is borderline, a lot of guys can run them with no issues. Do you have a build thread? If so let me know and I can add you to the chart. You don't need to have a huge build to justify a thread, anyone might have done something that another user can gain info from even if you aren't at 6 inches of lift and 33 inch tires.
by waldoinc » Fri Jan 13, 2012 10:04 am
I am running 265/65/17 SilentArmors
2 inch lift in front and back.
z71 springs and Bilstein HDs (front/back).
1.5 wheel spacers.
I have no issues.
waldoinc
by Outlaw_99 » Sun Jan 22, 2012 11:26 am
Awesome chart.. Just disappointed that I still need spacers after lift... :slap:
Thx for the info... Looks like Ill grab my spacers soon and put 265/70/17 on my blacked out stock rims...
Outlaw_99
by mikekey » Thu Mar 29, 2012 12:08 am
You can mark me down for 245/70/17 No lift (currently) and no spacers.
by Cable810 » Thu Jun 28, 2012 10:51 am
Could you mark me down 265/70/17(31.7 tall)? Link to my build in my signature
by 06MidnightBlue » Thu Jun 28, 2012 11:27 am
And if it isnt too much trouble, could you put me down for 265/75-16? thanx!!!
06MidnightBlue
by navigator » Thu Jun 28, 2012 1:33 pm
I added Mike, Caleb and Jeff.
by Gordinho80 » Thu Jun 28, 2012 2:35 pm
For what its worth, I'm running 285/75-16 tires now...
Mario -
by Cable810 » Thu Jun 28, 2012 6:23 pm
Thanks Chris!
by Cable810 » Thu Jun 28, 2012 6:26 pm
Is it just me or am I seeing 2 Ke7wox?!?!?!
by JCrayton99 » Thu Jun 28, 2012 7:18 pm
you can throw me in for 285-75-16, only have 3" of lift(w0rking on more, still rubbing....), trimming and spacer of course.
JCrayton99
Rank: Offroad Guide
by 06MidnightBlue » Thu Jun 28, 2012 8:26 pm
Thanks Chris!!!!
06MidnightBlue
