Wheel Spacers
by The Roadie » Tue Feb 18, 2014 5:28 pm
One stop shopping for a few of your issues:
viewtopic.php?f=14&t=4390
by Rcklssrdnck84 » Tue Feb 18, 2014 5:36 pm
:work: Thank you v7.. that's just what I needed.
Rcklssrdnck84
by HARDTRAILZ » Tue Feb 18, 2014 5:53 pm
Need more input.
Can't just tell you a blanket offset that works.
by Rcklssrdnck84 » Tue Feb 18, 2014 7:45 pm
I know it was very vague of a question. I'm sorry for that. I was only looking for a generalized size... a starting point if you will. I would like to use as close to factory size rims as I can get, but don't want to use wheel spacers, and still be able to run at least a 255/75/17. I know there is not a blanket size that works for all. I did not see that thread or I just overlooked it. :facepalm: I just don't want to make a costly mistake and waste money on rims I can't use. I appreciate all the help.
Rcklssrdnck84
by DustinC1989 » Tue Feb 18, 2014 8:01 pm
Best way to avoid a mistake would be factory/factory spec rims with good spacers. IMO
Anything else has multiple variables that very few have tried
DustinC1989
by Moots1288 » Tue Feb 18, 2014 8:15 pm
Rcklssrdnck84 wrote:I know it was very vague of a question. I'm sorry for that. I was only looking for a generalized size... a starting point if you will. I would like to use as close to factory size rims as I can get, but don't want to use wheel spacers, and still be able to run at least a 255/75/17. I know there is not a blanket size that works for all. I did not see that thread or I just overlooked it. :facepalm: I just don't want to make a costly mistake and waste money on rims I can't use. I appreciate all the help.
A 255/75/17 is a 32.. And will fit with a spacer and factory wheels.
by HARDTRAILZ » Tue Feb 18, 2014 8:24 pm
But he does not want spacers so about 4.5 inch backspacing with any offset should work. Since that is basically spacer equivalent.
by Moots1288 » Tue Feb 18, 2014 8:55 pm
HARDTRAILZ wrote:But he does not want spacers so about 4.5 inch backspacing with any offset should work. Since that is basically spacer equivalent.
Good luck finding that on our stock pattern :thumleft:
by djthumper » Tue Feb 18, 2014 9:00 pm
Piece of cake http://www.4wheelparts.com/Wheels/Wheel ... dth_PQ=8.5
by HARDTRAILZ » Tue Feb 18, 2014 9:08 pm
I would never tell anyone to keep our stock pattern but its his choice.
by Moots1288 » Tue Feb 18, 2014 9:11 pm
HARDTRAILZ wrote:I would never tell anyone to keep our stock pattern but its his choice.
Agreed.
by Rcklssrdnck84 » Wed Feb 19, 2014 5:15 am
What's so bad about the stock pattern? Aside from it being so odd-ball?
Rcklssrdnck84
by DustinC1989 » Wed Feb 19, 2014 5:19 am
Odd ball = crap for wheel options
DustinC1989
by navigator » Wed Feb 19, 2014 4:16 pm
it can be hard to find wheels in our pattern with enough offset to run the larger tires at a reasonable price.
by djthumper » Wed Feb 19, 2014 5:58 pm
navigator wrote:it can be hard to find a variety of wheels in our pattern with enough offset to run the larger tires at a reasonable price.
Fixed it for you. :finger:
I believe my link shows plenty...
by Moots1288 » Wed Feb 19, 2014 6:03 pm
your link didnt show me any..
by The Roadie » Wed Feb 19, 2014 6:07 pm
The link (for us) goes to the beginning of a search. Perhaps you had a display at the end. When I punched in 2004 GMC Envoy, it showed zero options. I concluded it was a was a front end for a flawed data base, and that was your intent. To show the paucity of options out there.
by RyansTBLS » Wed Feb 19, 2014 6:09 pm
I put the options in for my trailblazer and it gave me like 3 different options. :mechanic:
RyansTBLS
by djthumper » Wed Feb 19, 2014 8:06 pm
by HARDTRAILZ » Wed Feb 19, 2014 9:29 pm
Pricey...
