The Complete Lifts and Suspension Accessories Thread
by Gordinho80 » Tue Sep 08, 2009 10:57 am
by Gordinho80 » Wed Aug 18, 2010 12:15 pm
Suspension Lifts (Spacers)
** BDS 2" Suspension Lift - http://www.bds-suspension.com/kits/168H
2" CHEVY TRAILBLAZER/GMC ENVOY
INSTALL INSTRUCTIONS: http://bds-suspension.com/instructions/011201.pdf" onclick="window.open(this.href);return false;
The BDS suspension lift completely gets rid of the upper shock mounting method and provides a single lifting component made of powdercoated steel. This block lifts the spring, and also readjusts the upper shock mounting point to provide a bit more downward articulation. It provides improved shock mount bushings that resists the wear and tear of heavy duty use.
Front 2" Strut Mount
Rear 2" Coil Mount
This system includes two new upper strut mounts that replace the factory upper stut mount. The one piece mount increases the pre-load of the strut as well as increases the over all length of the strut assembly. The rear is lifted via two upper coil spring mounts. New rear 5500 series shocks are also included in the kit.
MAX. TIRE SIZE: 30 x 9.50"
MAX. WHEEL SIZE: 17 x 7
BACK SPACING: Stock
EST. INSTALLATION: 3 to 4 hours
DIFFICULTY LEVEL (easy 1 - 5 complicated): 3
**ANOTHER NOTE** LiftMeister or Suspension Maxx Additional front spacers can be stacked with the BDS front kit, to give a total of 2.75" of lift in front... Pics of difference - http://forums.offroadtb.com/phpBB/viewtopic.php?f=11&t=21
** Rough Country - Suspension lift http://www.roughcountry.com/chevy_trailblazer_leveling.html
The Rough country is essentially a copy of the BDS kit, however it seems to be made of lighter-gauge metal. It appears to utilize an improved upper-shock mount also.
** Radflo Custom OEM replacement Coilovers http://forums.offroadtb.com/viewtopic.php?f=15&t=3002
The coil over has been tested by a few of our members, and is ready for sale. Contact Johnny at Wheeler's Off-Road for purchasing.
** SuspensionMaxx Spacers - http://www.suspensionmaxx.com/chevy/chevy-leveling-kit/chevy-trailblazer-leveling-kit-2002-2008
Front Lift Spacers, up to 2.5" lift
SMX-10100 - 1.5 INCH
SMX-10125 - 1.75 INCH
SMX-250XL - 2.5 INCH
SMX-ST50 - .75 INCH Top Spacer
Rear Lift Spacers, up to 2" lift
SMX-15100 - 1 INCH
SMX-15150 - 1.5 INCH
SMX-15200 - 2 INCH
** LiftMeister Suspension Lift Spacers - http://theliftmeister.com/public_html/theliftmeister.com/
3" suspension lift kit
This new design replaces the OEM upper strut mounts with a better bushing,
and has been hard trail tested for durability with amazing results.
Kit works best for anyone adding extra weight to front such as steel bumper.
Kit includes:
2pcs 3" front lift spacers w/new bushings and m10 flange nuts.
2pcs 2" rear lift spacers
2.5" suspension lift kit
This 2.5" suspension lift has been long time tested as one of the most economical lift/level kit on the market.
Kit is designed to be used with OEM struts and shocks.
Kit includes:
2pcs 1.5" thick in assembly aluminum spacers
2pcs 0.5" thick above assembly aluminum spacers
2pcs 2.0" rear aluminum lift spacers
2pcs washers
4pcs m10 locking flange nut
** Truxxx Lift and Level Kit - http://www.tirerack.com/suspension/suspension.jsp?make=Truxxx&model=Lift+and+Level+Kit
Rear Lift Spacers, up to 1.25” lift
** Ready Lift - Suspension lift http://www.readylift.com/c-196-trailblazer-sst-lift-kit-2002-2009-2wd-4wd-20f10r.aspx
***The Ready Lift is an easy-bolt-on unit, and does not require taking the strut apart. For that reason, this lift can be dangerous and should not be installed on a 4x4. This lift is acceptable for 2WD vehicles only. This lift will over extend the inner CV joint angle, and cause major driveline issues on a 4x4.
by Gordinho80 » Wed Aug 18, 2010 12:17 pm
Alternative Springs (Front)
** Factory GM Springs – http://forums.offroadtb.com/viewtopic.php?f=15&t=158 - GM Parts #15125881, 15125882, 15125883, 15125884, 15125885, 15125886, 15125887, 15125888, 15125889
It has been found that GM offered many different springs with the GMT-360 platform. By installing a higher spring rate coil, you would lift the stance of the vehicle because of the higher stiffness of the spring.
Alternative Springs (Rear)
** Avalanche/Tahoe/Suburban Z71 Springs - GM Part #15234633 or #25978750
We have learned that 2007-2012 Tahoe Z71 rear coil springs actually work in our vehicles. The springs are stiffer and provide ~1.5" of lift in the rear only, however are the same uncompressed length as the stock trailblazer springs.
** Skyjacker Softride Coil Springs - C25R
We now know that the Skyjacker Softride Coil Spring, designed for the Tahoe/Suburban/Yukon, C25R, effectively gives our vehicles approximately 4" of lift over stock in the rear. This is a great way to get maximum lift in the rear without spacers.
by Gordinho80 » Wed Aug 18, 2010 12:18 pm
Body Lifts
** Zone Offroad 2" Body Lift - http://zoneoffroad.com/product?ki=191&gr=-1
2" Trailblazer Body Lift
The Zone body lift lifts the body in relation to the frame. This 2" body lift is perfect to add that little extra tire clearance that you need. The system relocates the front and rear bumpers to maintain a factory look. Grade 10.9 body bolts are included along with Zone Offroad's Crush-Proof body blocks. Zone bought this kit from BDS.
Currently unavailable due to vendor issues - ** High-Voltage 3" Body Lift - http://forums.offroadtb.com/viewtopic.php?f=21&t=2503
3" Trailblazer/Envoy Body Lift
by Gordinho80 » Wed Aug 18, 2010 12:21 pm
Shocks & Struts
** BDS Rear Shocks
More and more members are going the BDS route for rear shocks with their lifts. The 2 most popular options are the 5500 (Hydraulic) and the new Fox 2.0 Performance Series series.
Hydraulic Shock Absorber - #55619
Fox 2.0 Performance Series - #98224619
Another rear shock option that requires washers to center in the mount is the skyjacker n8030
** Bilstein HD Shocks/Struts
Many people use the Bilstein HDs. They offer a higher dampening rate that helps improve vehicle control when in bumpy or rocky areas.
FRONT: Trailblazer/Envoy replacement: F4-BE5-A333-H0
REAR: Trailblazer/Envoy replacement: F4-BE5-A335-H0
REAR: Tahoe/Yukon 4x4 Replacement: F4-BE5-E375-H0
REAR: Avalance/Suburban/Tahoe/Yukon Replacement: F4-BE5-E380-H0
by Gordinho80 » Wed Aug 18, 2010 12:22 pm
Other, non lift, suspension components
** AirLift 1000 Air Bags - http://www.airliftcompany.com/products/air-springs/airlift-1000
Part # 60779 - For STOCK Trailblazer/Envoy/etc Rear Springs
Part # 60769 - For Avalanche/Tahoe/ Rear Springs
Up to 1000lbs of load leveling capability - used to increase rest height and aid with loaded cargo area, prevents rear sag...
Airlift 1000 bags allow the user to adjust the spring constant of their rear springs. This means the user can 'preload' the bags with pressure, to counteract a heavy load or trailer tongue weight. It also can provide lift, but also stiffens the springs.
**MAXXLinks - Heavy Duty Sway Bar End Links - http://www.suspensionmaxx.com/chevy/chevy-sway-bar-link/chevy-trailblazer-xl-sway-bar-link-2002-2008
*Available for Stock & Lifted vehicles up to 2 inches.
Maxx Link Heavy Duty Front Sway Bar End Links for 2002-UP 4X4 / 2WD Trailblazer, Envoy, Bravada, Ranier, Isusu Asender (includes XL models). Made from a combination of high grade steel and corrosion-resistant components, the MAXXLink end link system utilizes simple, effective design in conjunction with sturdy, robust parts to achieve outstanding performance and long-lasting results.
No more changing your truck or SUVs sway bar links every fifty thousand miles. MAXX Links are engineered to work hard and built tough to last long! Perfectly suited as a high-quality replacement piece or as a preventative maintenance measure for hard working trucks and SUVs, now owners have one less suspension piece to worry about thanks to the innovative experts at Suspension MAXX! Available for Stock, Leveled /Lifted Trucks. Backed with a lifetime warranty!
SMX-K666F - FRONT
SMX-K666R - REAR
