Leaning to the Left!?!?!
by Moots1288 » Tue Sep 17, 2013 9:22 pm
Image like that
by mikekey » Sat Dec 07, 2013 7:36 pm
Yes, I'm reviving an old thread. Has anyone to date replaced their body mounts that are collapsed? I've been searching the forum for the last half hour and haven't been able to come up with a part # and Rock Auto has zilch.
Unless "Body mount" is the incorrect term. :?:
by Moots1288 » Sat Dec 07, 2013 7:44 pm
mikekey wrote:Yes, I'm reviving an old thread. Has anyone to date replaced their body mounts that are collapsed? I've been searching the forum for the last half hour and haven't been able to come up with a part # and Rock Auto has zilch.
I think they call it a body bushing and just for that upper half is 70$ so right now I have not swapped out that one bushing that is collapsed. I tried looking for it with calling it a mount and got better luck with "body bushing"
by mikekey » Sat Dec 07, 2013 8:19 pm
$70!!! NO THANK YOU.
I still can't find it on RockAuto with body bushing either. Oh well, if it's that much maybe I'll just go to the junk yard.
by Moots1288 » Sat Dec 07, 2013 9:13 pm
mikekey wrote:$70!!! NO THANK YOU.
if you can find it online cheaper let me know. I looked quite a bit man. Hopefully you have better luck
by TBYODA » Sat Dec 07, 2013 10:12 pm
Hockey puck;)
by mikekey » Sat Dec 07, 2013 10:15 pm
I am a cut ally wondering if the energy suspension body mounts might work.
by Moots1288 » Sat Dec 07, 2013 10:17 pm
mikekey wrote:I am a cut ally wondering if the energy suspension body mounts might work.
hmm.
by mikekey » Sat Dec 07, 2013 10:19 pm
Autocorrect ruins my life.
by dvanbramer88 » Sat Dec 07, 2013 10:20 pm
You got a lathe, can't you make something?
by ErikSS » Sun Dec 08, 2013 1:54 am
I checked your build sheet. It says that a body lift was in your future plans. Do you have a body lift on now? Did you have a body lift on when you suffered that right rear body damage?
by v7guy » Sun Dec 08, 2013 4:43 am
I had to replace one of mine when it loosened up and the lower half fell out. Body cushion (body to frame) is the correct term and you can apparently only get it from GM. The lower half is approximately 40 and the upper half is approximately 70. You'll also find the part numbers have been changed at least once.
Here's one source
http://www.tonkinonlineparts.com/showAs ... bly=813876
by mikekey » Sun Dec 08, 2013 9:35 am
Thanks, that's about all that's come up. Energy suspension makes some and makes a universal kit. This isn't high on the priority list, and only two have crushed. But I might measure them to see if there are alternatives for half the cost.
by Aries » Sun Dec 08, 2013 11:08 am
When I did the body lift the other day I was thinking “It would be nice to change out these cushions while I have the body lifted” But I see where the cushions are mostly one piece that inserts down into the frame mount. I also see from the diagram some have different part numbers? I don’t see where Energy Suspension carries anything compatible. Gonna have to put a call into ProThane and see what’s available. If some could message Bo Richie over on TBSSOwners.com to get his input, I don't have permission to message members . I would like to change mine out.
http://www.tonkinonlineparts.com/showAssembly.aspx?ukey_product=6038859&ukey_assembly=831342
Aries
by Cable810 » Sun Jan 26, 2014 11:06 pm
ErikSS wrote:I checked your build sheet. It says that a body lift was in your future plans. Do you have a body lift on now? Did you have a body lift on when you suffered that right rear body damage?
Just happening to be going through this and read this. No I have yet to install nor have I installed a Body Lift.
