offroadTB.com • View topic - How to upgrade to EXT/SS Brake Upgrade
by mikekey » Tue Oct 01, 2013 4:05 pm
Well if you want to go all crazy here:
ACDelco 172-2501 OE Service Front Brake Caliper - Qty 2
ACDelco 177-1050 OE Service Front Brake Rotor - Qty 2 - 15 inch rotors!!!!!
Front Brake Caliper Pin Kit - 25940448 - Qty 2
M14x2.0x40 Flange Bolts (Fastenal) - Qty 4
Problem is you're not going to fit these inside 17 inch rims, 18 inch, yes with proper back spacing.
by DirtyBacon04 » Tue Oct 01, 2013 4:46 pm
Y'all keep saying EXT/SS brakes and i'm assuming thats including a bigger rotor? If thats the case, i guess my 8.6" ext rear end was strange. it had the same size rotors as my 8". I just swapped my old ones over to the new axle.
by dvanbramer88 » Tue Oct 01, 2013 4:53 pm
by mikekey » Tue Oct 01, 2013 5:02 pm
by Moots1288 » Tue Oct 01, 2013 5:24 pm
by ErikSS » Tue Oct 01, 2013 6:11 pm
Poor Moots. 16" wheels.
by Moots1288 » Tue Oct 01, 2013 6:12 pm
by ErikSS » Tue Oct 01, 2013 6:15 pm
by Moots1288 » Tue Oct 01, 2013 6:26 pm
by ErikSS » Tue Oct 01, 2013 6:42 pm
That looks good. Maybe you could go that route. I wonder if the steel SS calipers are larger than the EXT calipers. I tried some 16" wheels and wasn't even close. Perhaps I didn't put in the effort to try all angles. I just went 17" wheels, solved all my problems. lol
by mikekey » Tue Oct 01, 2013 6:47 pm
Eric they're the same, yours just weigh more.
by Moots1288 » Tue Oct 01, 2013 6:47 pm
by ErikSS » Tue Oct 01, 2013 6:49 pm
I just know AJ had to grind the crap out of his calipers to run 15's on his 2005 LT. I know cause I did it. haha It was mostly his rear now that I think about it. Give her hell!
by Moots1288 » Tue Oct 01, 2013 6:53 pm
by HARDTRAILZ » Mon Nov 25, 2013 1:21 am
Mike....your 1st post is right....be wary of Ebay.
SS front rotors wont fit EXT... something doesn't add up.
Searched for 06 SS and then cross checked with 06 ext v8.
Those should be same front rotors correct?
by jonbo2002 » Mon Nov 25, 2013 7:16 am
jonbo2002
by HARDTRAILZ » Mon Nov 25, 2013 7:42 am
I believe SS and Ext should be same rotors.
Looking more for confirmation than knowing what to order.
Did find my pads are lifetime guarantee so only need rotors and I am good to go.
by jonbo2002 » Mon Nov 25, 2013 8:11 am
jonbo2002
by HARDTRAILZ » Mon Nov 25, 2013 8:36 am
Won't use aitozone. One rotor is price of pair online.
by jonbo2002 » Mon Nov 25, 2013 8:51 am
oh I know that I was just showing the difference. and I know yours came off an 03 Envoy for sure. So I was just saying through the vendor on ebay you are ordering just make sure they list them for an 03 Envoy ext. I don't want you to end up with the wrong rotors
jonbo2002
