offroadTB.com • View topic - Rear shock and spring discussion
by djthumper » Sun Nov 17, 2013 4:57 am
I am definitely waiting to hear a report of the N8030s with the SkyJacker springs. I can't believe how many people are running the shocks that started with a search that Kyle and I started to see what else was out there other than BDS before they got the Fox shocks.
by ErikSS » Sun Nov 17, 2013 12:19 pm
I bought mine in March 2013 (yes, this year) because MarkMC suggested them... and the price was very reasonable.
by v7guy » Sun Nov 17, 2013 1:23 pm
They're a real valid option. They're only a half inch shorter than the BDS/Fox shocks and both are gas charged so they're really vaild comparisons.
I can offer input on the fox shocks with the Z71 springs. They dampen the springs about as well when it's unloaded as when I'm running around with hundreds of lbs in the hatch area. It doesn't matter if it's a stack of 15-20 sheets of green board or if it's piles of wood from a 20" trunk on a 2.5 story tree... or if I'm going to work with a duffle bag of gear in the back. It just works.
The fox shocks with the skyjacker springs seem to work well under a moderate load as I've experinced in Moots truck. They seem to work well with a couple hundred lbs. A bit softer/bouncier, which could be good or bad. But I've not been in his truck with hundreds and hundreds of lbs in it.
by ErikSS » Sun Nov 17, 2013 3:03 pm
by Moots1288 » Sun Nov 17, 2013 3:09 pm
by mikekey » Sun Nov 17, 2013 3:19 pm
I think some folks here just like their rigs to ride like soft Cadillacs and not as HARD as they claim. :poke:
by Moots1288 » Sun Nov 17, 2013 3:36 pm
I love my Cadillac envoy
by JorDaneeKey » Sun Nov 17, 2013 4:31 pm
As told by the other half:
JorDaneeKey
by ErikSS » Sun Nov 17, 2013 4:56 pm
"You Smashed Every Single Bottle!" hahaha Great Video JorDanee
by dvanbramer88 » Sun Nov 17, 2013 5:07 pm
by mikekey » Mon Nov 18, 2013 8:12 am
I just want to try the setup so I can be qualified to trash talk too. Hehehe.
But in all seriousness, while the Z71s ride more truck like which is fine for me, I was thinking about little passengers and making a better ride, so why not test out a different setup.
by HARDTRAILZ » Mon Nov 18, 2013 9:52 am
To anyone wanting Skyjacker rear spring opinions...please ask Moots, Regulator or myself since we have owned and used them daily.
by v7guy » Mon Nov 18, 2013 12:17 pm
by TBYODA » Mon Nov 18, 2013 12:57 pm
by HARDTRAILZ » Mon Nov 18, 2013 12:59 pm
I know the shocks are a big portion.
Jason... maybe the MX6 or RS9000 or something similar. I know there are others but if I remember right those are decent price w 6 n 9 levels of adjustment.
by v7guy » Mon Nov 18, 2013 1:31 pm
I think either one would be a real valid choice for something to play with. You're stuck with what they select for the rebound adjustment, but as I mentioned before, I'm inclined to think that the compression is the bigger issue in the z71s and skyjackers. I can't think that the rebound would be far off. So being able to dial in the stiffness would probably really help the skyjackers and the z71s a lot. I was surprised too cause the price isn't bad, right inline with the Fox/BDS shocks Moots and I have.
Personally I'm really leaning towards FOA for the latest TB project, they're cheap, and despite some problems initially, the warranty is solid and they have a reasonable reputation on pirate. You can open em up and revalve them if you're inclined... most of the forums say you should at minimum open em up and clean the metal shaving out :eek:
Given the cost of the race bilsteins on the firebird that can also be revalved (I've really appreciated that ability) the FOA stuff seems like a steal. But they are more of a "tinker with it" project shock. They probably aren't worth it for most people especially if the adj shocks can be tweaked enough for the spring each of us is using.
