offroadTB.com • View topic - Help with shocks
Help with shocks
by CNCwell » Sat Nov 02, 2013 7:40 pm
My lift 3" lift shipped today. I been reading on here for days trying to decide which shocks to use. I think it is narrowed down to BDS, Bilstein, Rancho or Skyjacker. Does anyone have a preference on these? If so is there any out there that would be a direct bolt on after my 3" LiftMeister lift is installed? If you could give me part numbers also that would be great. (Don't worry, I won't ask anyone to come install them!haha)
--Anais Nin
CNCwell
by ErikSS » Sat Nov 02, 2013 8:00 pm
As Mark recommended when I bought my 3" lift from him this spring, I bought the Skyjacker N8030. I've never run the others, but I'm happy with my Skyjacker.
by Moots1288 » Sat Nov 02, 2013 8:24 pm
A couple of guys have skyjackers and like them, me and v7guy have bds.fox 2.0 shocks and I am a fan of them.
by TBYODA » Sat Nov 02, 2013 8:36 pm
by CNCwell » Sat Nov 02, 2013 9:01 pm
Thanks guys. I am luckily a Prime member so I am getting the Skyjackers. Also what about struts?
--Anais Nin
CNCwell
by mikekey » Sat Nov 02, 2013 9:04 pm
What about them?
by TBYODA » Sat Nov 02, 2013 10:20 pm
Take a look here, man do a little reading. viewtopic.php?t=20 part number are all there.
by HARDTRAILZ » Sun Nov 03, 2013 7:28 pm
N8030 are 76 bucks delivered off Ebay for a pair. Mine should be here tomorrow.
by navigator » Sun Nov 03, 2013 7:33 pm
I run the skyjacker N8030s as well.
You'll need a bunch of little washers though to take up the difference in space. I think I used like 8 3/8" grade 8 washers on each side of each shock for a total of 32 washers. I could be off on the count though, someone might have a better memory than I do. the main point is that you'll need to add washers on each side of the shock to fill in the gap on the lower end unless you can press the spacer/bushing out of your factory shocks.
by Cable810 » Sun Nov 03, 2013 8:06 pm
Skyjackers Are what I'm using 0 issues. I used 5 washers on each side. I think I used 3/16s grade 8 washers....
by Opeth » Sun Nov 03, 2013 8:31 pm
Bilstein 5125's here
by ErikSS » Sun Nov 03, 2013 8:43 pm
by firefox2501 » Sun Nov 03, 2013 10:20 pm
For the fronts, you will notice a trend in the build threads. Most folks are running Bilstiens. If you want to splurge, get the Radflo Coil Overs.
For the rears, there is more diversity, but once again, check the build threads and check the link that TBYODA provided. () I have the Skyjacker 8030s. (~$45 each with Amazon Prime). But instead of a bunch of washers on the bottom shock mount, I picked up a couple nylon spacers at the local hardware store. Been running them for a year with no problems.
The spacers are 1/2" tall with an inside diameter of 1/2". Notice the single washer between the spacer and the shock.
firefox2501
by TBYODA » Sun Nov 03, 2013 10:32 pm
by Moots1288 » Sun Nov 03, 2013 10:37 pm
by firefox2501 » Sun Nov 03, 2013 10:43 pm
Moots beat me to it. It is the sleeve from the bushing.
That is the reason for the washers on the inside - to keep the sleeve centered on the bushing.
firefox2501
by Trail X » Sun Nov 03, 2013 11:05 pm
Nice solution Mike. I was going to post up and say that grade 8 washers aren't exactly necessary here. Your nylon more than proves that.
by TBYODA » Sun Nov 03, 2013 11:10 pm
Ok would not the shock move some since there is some space there or is really insignificant.
by firefox2501 » Sun Nov 03, 2013 11:14 pm
It is going to move on the sleeve regardless of whether you are using a bunch of washers or the spacer+washer combination.
But looking at that picture above, I recall it looking the same way when I installed it. So it is probably insignificant.
firefox2501
by firefox2501 » Sun Nov 03, 2013 11:16 pm
firefox2501
