It's possible to physically remove the front driveshaft, but there is no electrical or mechanical disconnect unit to stop the AWD functionality short of removing the driveshaft.
The encoder motor is the same except on the AWD NVG126, there is no brake. It's always available to move freely under control of the TCCM (Transfer case control module) which is the electronic box always looking for wheel slippage.
The clutch packs are engaged by the encoder motor to send more or less torque forward as wheel slippage is detected. Normal minimum torque sent to the front differential is 5%. It's not "viscous" in the way other vehicles are designed. It's a set of clutches, and they are always rotating.
When you drain the TC, measure how much comes out. That will be an indication how much damage is already done.
Also check the level and refill the front diff. At 100K, ALL fluids and the spark plugs are due.
We have an article here on the NP (NVG) 226 that the on-demand 4WD system uses. Our A4WD mode is mostly what the NVG126 uses all the time.
http://www.offroadtb.com/articles/tech- ... -operation
