offroadTB.com • View topic - TB EXT Lift Guidance
by 80Flareside » Wed Aug 08, 2012 9:51 am
Hey all, pretty new member here, looking for some help and clarification on lift options. Ive read through many of the threads here, and at TrailVoy regarding lifts, but the more I read, the less I am sure how to go about what I am trying to achieve.
Im by no means a master mechanic, but Ive successfully (not always the first time, but eventually) rebuilt the C6 transmission, NP208 T-Case, and Dana 44 TTB on my truck, so I have the skills and background to accomplish this, I just cant figure out what I path I should take.
Scenario:
The TB is the wifes car, but its also what we use whenever we go anywhere as a family. It was bought used, and the dampening on the shocks is miserable (either worn out or way to soft for my liking - not sure which as I have nothing to compare it to), and she needs new tires. We plan to get a pop-up camper next year, somewhere around the 2,500 - 3,000 lb range, and this will be the vehicle we tow it with. 99% of what it will see is pavement, but there are some "4x4 - High Clearance" Class 4 roads in VT that we travel every so often.
Goals:
Increase the load handling ability of the vehicle
Improve dampening of compression and rebound of shocks
Improve clearance
Achieve slight rake from front to back (but less than factory) so it rides level with a moderate load
What Ive concluded so far:
Rear - Z71 springs, Bilstein 5100 Shocks, Bumped and Strapped
Front - Bilstein HD (Yellow Body) Shocks
Tire Preference - BFG Rugged Terrain T/A
Questions:
How much lift will the Z71's provide in an EXT? (assuming the figures I see here are for SWB)
How much lift can I give the front with out a UCA flip?
What is the largest tire I can run at that lift without a spacer?
What spring options are available for the front, and how do they affect ride height when combined with spacers?
What exactly are "86's", "87's", etc?
thanks in advance ~ matt
80Flareside
by 06MidnightBlue » Wed Aug 08, 2012 10:16 am
The Z71's will give you about an inch of lift.
The most lift you should do in the front without flipping the UCA's, IMO, is 2.5 inches.
The largest tire you can run without spacers is 30.5.
There are a few spring options, with the stiffest option providing about 1.25 inches of lift in the front.
The "86's" and "87's" refer to the spring rate.
Most of this could have been found by searching.
06MidnightBlue
by Gordinho80 » Wed Aug 08, 2012 10:23 am
Mario -
by 06MidnightBlue » Wed Aug 08, 2012 10:33 am
Thanks for the clarification Mario. Not quite awake yet
06MidnightBlue
by The Roadie » Wed Aug 08, 2012 10:56 am
One question you asked I don't remember ever seeing before was about the UCA flip. Pretty much only the max lifts *require* the frip to allow the alignment shop to come closer (or to achieve) an in-spec camber adjustment. But flipping the UCA with ANY amount of lift can only help reduce stress on the upper ball joint because it puts the ball shaft closer to being centered. I don't think there's any downside, and if you're in there with the struts removed, all it takes is a short amount of time to flip them. You need an alignment anyway after the lift, so it's good to do it all at the same time.
by 06MidnightBlue » Wed Aug 08, 2012 11:34 am
Roadie does make a good point.
06MidnightBlue
by 80Flareside » Wed Aug 08, 2012 1:57 pm
80Flareside
by Trail X » Wed Aug 08, 2012 2:03 pm
by fishsticks » Thu Aug 09, 2012 5:17 pm
by fishsticks » Thu Aug 09, 2012 5:34 pm
Also, I think your cooling post merited it's own topic, so I split it off for you. Found now.
by Trail X » Thu Aug 09, 2012 6:43 pm
by 80Flareside » Thu Aug 09, 2012 10:07 pm
80Flareside
by 80Flareside » Fri Aug 10, 2012 9:33 am
80Flareside
by The Roadie » Fri Aug 10, 2012 11:22 am
by Trail X » Fri Aug 10, 2012 11:31 am
by navigator » Fri Aug 10, 2012 5:00 pm
by v7guy » Sat Aug 11, 2012 8:58 am
I've wondered for about 6 months now if it would be feasible to make a sleeve to fit around the lower tube of an exsisting shock with the groove for the bolt/pinch part of the dogleg. Could probably incorporate a lower spring mount so we could just use whatever shock we wanted. Maybe it would be fine, or maybe it would bend the shock tube. I dunno.
It would be relatively simple to turn on a lathe. Bet somebody could market them for relatively cheap if it was without a lower spring mount.
It's the only way I can think of to open up the shock options for the front.
by The Roadie » Sat Aug 11, 2012 11:41 am
by Trail X » Sat Aug 11, 2012 12:14 pm
How would it hold on to the shock alternative? Just clamp force? That spring is so strong that it could pull your shock out of the hold.
by chevycrew » Sat Aug 11, 2012 1:24 pm
you could have the new shock slide into the sleeve/lower mount, then once fully seated a bolt would be placed through the lower shock eye to lock it into place.
