by 80Flareside » Wed Aug 08, 2012 9:51 am
Hey all, pretty new member here, looking for some help and clarification on lift options. Ive read through many of the threads here, and at TrailVoy regarding lifts, but the more I read, the less I am sure how to go about what I am trying to achieve.
Im by no means a master mechanic, but Ive successfully (not always the first time, but eventually) rebuilt the C6 transmission, NP208 T-Case, and Dana 44 TTB on my truck, so I have the skills and background to accomplish this, I just cant figure out what I path I should take.
Scenario:
The TB is the wifes car, but its also what we use whenever we go anywhere as a family. It was bought used, and the dampening on the shocks is miserable (either worn out or way to soft for my liking - not sure which as I have nothing to compare it to), and she needs new tires. We plan to get a pop-up camper next year, somewhere around the 2,500 - 3,000 lb range, and this will be the vehicle we tow it with. 99% of what it will see is pavement, but there are some "4x4 - High Clearance" Class 4 roads in VT that we travel every so often.
Goals:
Increase the load handling ability of the vehicle
Improve dampening of compression and rebound of shocks
Improve clearance
Achieve slight rake from front to back (but less than factory) so it rides level with a moderate load
What Ive concluded so far:
Rear - Z71 springs, Bilstein 5100 Shocks, Bumped and Strapped
Front - Bilstein HD (Yellow Body) Shocks
Tire Preference - BFG Rugged Terrain T/A
Questions:
How much lift will the Z71's provide in an EXT? (assuming the figures I see here are for SWB)
How much lift can I give the front with out a UCA flip?
What is the largest tire I can run at that lift without a spacer?
What spring options are available for the front, and how do they affect ride height when combined with spacers?
What exactly are "86's", "87's", etc?
thanks in advance ~ matt
