Front spacers only okay?
by AceOfSprings » Thu Aug 02, 2012 6:52 pm
So I bought marks 2.5" lift. Have the front installed with blistien hd shocks. Now for the rear I was trying to install the skyjacker c25r s that I have but simply cannot compress them enough to fit the spacer in. So im thinking they will just naturally add enough lift. Is it okay to install these springs without the spacers and keep the front spacers only?
AceOfSprings
by DirtyBacon04 » Thu Aug 02, 2012 7:57 pm
yea
by v7guy » Fri Aug 03, 2012 1:22 am
Won't hurt a thing.
by fishsticks » Fri Aug 03, 2012 1:25 am
Your truck might catch fire...
by AceOfSprings » Fri Aug 03, 2012 1:34 am
Sent from my mind
AceOfSprings
by v7guy » Fri Aug 03, 2012 1:34 am
:camping:
by 06MidnightBlue » Fri Aug 03, 2012 2:27 am
Hope it still drives in a straight line...
06MidnightBlue
by navigator » Fri Aug 03, 2012 8:07 am
I have to say this...
To be "AceOfSprings" you sure do ask a lot of questions about them.
Sorry but I had to say it :poke:
Don't worry I'm just as likely to ask a bunch of questions about GPS software later on.
Feel free though man, that is why we are here.
Install without the rear spacer and see how you like the look.
If you want more lift in the rear, try disconnecting the rear sway bar, that should give you a little more room to play with.
by The Roadie » Fri Aug 03, 2012 12:10 pm
Something to fix here? :poke:
by v7guy » Fri Aug 03, 2012 12:59 pm
The Roadie wrote:Something to fix here? :poke:
I thought they came from the factory like that :facepalm:
by Trail X » Fri Aug 03, 2012 1:04 pm
A sheet metal screw fixed mine!
by DirtyBacon04 » Fri Aug 03, 2012 4:11 pm
JamesDowning wrote:A sheet metal screw fixed mine!
Gorilla Glue for me.
by DirtyBacon04 » Fri Aug 03, 2012 4:18 pm
From my experience, THEY DO!
by Mudwheelin » Fri Aug 03, 2012 5:53 pm
I gave up fixing mine. Everytime I'd fix it, it would just hang down like that in another spot. Everyone I see is like that to. Stupid design.
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by navigator » Sat Aug 04, 2012 11:31 am
I used some kind of glue to fix mine on both sides.
