Tried to disco Josh's rear sway bar today. The bolt just spins in the bushing when you try to loosen the nut on the end link. Apparently this is very common and most just cut the end links.
My Questions: Do you prefer a sawzall or grinder with cut off wheel? (Torch isn't an option)
Where do you cut the end link?
Is there anything i should try first before cutting? I loaded them up with WD-40 today, but the bolts did spin fairly easy. I'm afraid to heat them in fear of burning the bushing up. Any tricks?
