U Joints Going bad after Lift?!?!
by Cable810 » Wed May 02, 2012 6:21 pm
Quite a few people that I have talked to about my lift(telling them what I'm doing and such) said/suggested that I replace my U Joints shortly after I lift. I searched and didn't really find anything. Unless I'm looking in the wrong spot? From what I read and have been told we are more likely to have problems w/our CV boots comeing off, BJ going bad, Tie Rods, Hub Bearing/Assembly, and End Links than anything else. AM I wrong?
Anyone have there U Joints go bad after lift?
by chevycrew » Wed May 02, 2012 9:35 pm
Nope, Ive never heard of that and Ive lifted many rigs, personal and at the shops ive worked...
by navigator » Wed May 02, 2012 10:00 pm
I think with older jeeps the U joints would develop a wear pattern and when you lifted them the angle was a little different so they would make more noise. The issue was the joints were already worn, the lift just made that more clear.
by Cable810 » Thu May 03, 2012 8:32 am
Ok I don't know why people are telling me all of this, I plan on replacing the BJ, and Tie Rods ASAP after the lift and putting some hose clamps on the CV Boots. Then we see what happens from there.
Thanks guys!!
by navigator » Thu May 03, 2012 9:25 am
depending on your mileage your BJ and tie rods might actually be ok.
I'm at 95k and my TB has mostly seen highway miles until recently and they are still good.
Yours is a lot older but might be ok as well. If your TRE are questionable I would go ahead and replace them so you only have to get one alignment.
by DirtyBacon04 » Thu May 03, 2012 11:32 am
:Iagree:
I'm at similar mileage and by BJs are still good. Of course, theres never any harm in replacing suspension components, maybe just no need either. The choice... is yours.
by HARDTRAILZ » Thu May 03, 2012 11:32 am
Wow. Some of the people you get advice from...
by Cable810 » Thu May 03, 2012 11:37 am
HARDTRAILZ wrote:Wow. Some of the people you get advice from...
Yea, thankfully I have Ya'll that have done this and know our platform inside and out :D !! My OD shows 139K few hundred away from 140K, but thats not the actual miles. Its probally closer to 150K -160K. Uncle put a OD stopper on it....
by DirtyBacon04 » Thu May 03, 2012 11:38 am
HAHAHAHAHAHAHA!!!!!! :lurk: :lol:
by Badgerfan1181 » Thu May 03, 2012 11:46 am
The people at the shop may be thinking of the older blazers like late '80s my dad had a lifted one and the U joints went out yearly that's the first thing he told me when i brought up lifting mine
Badgerfan1181
by Cable810 » Thu May 03, 2012 11:50 am
This wasn't at the shop it was a friend of my dads. We hunt his property during Deer, Turkey Season.
by navigator » Thu May 03, 2012 12:06 pm
I know with the jeeps, they have U joints on the front axles and when you lift you are changing that angle a good bit and the wear becomes more noticeable. We don't have U joints on our front axles to wear.
