so with that being said...how worried do I have to be about this with the 2.5 lift? I would have to go to maximum excursion in order for it to happen, yes?
Thanx dudes!!
hobbstisdaman wrote:Couldn't you not have to use the pry bar if you just used a long jack to separate the axle and the top part far enough apart?
The Roadie wrote:It's best if you know WHAT you're overstressing if you need to use a bottle jack. Brake lines are a bit riskier to stress than a connected anti-sway bar.
