JamesDowning wrote:Paul,
Transgo does make a replacement plate for the 07:
http://www.transmissionpartsusa.com/4L6 ... 35098d.htm Might want to look into it. No gaskets, but they are only like $4 if I recall.
3 hours, wow. Took me basically 7 if I recall. Did you make the changes to the 2-4 servo? I had heard to stay away from it. Now your testimony tells me that I may have done the right thing. Do you also notice a rather harsh 3-4 shift?
I pulled the cover to get the code off of it, but didn't make any changes, I was going to put in the Corvette 2-4 servo, but didn't end up putting it in, since I've heard it increases the shifts also. The 1-2 valve spring I used was the lightest one in the pack, and was almost the same as the stock one, I'm curious to see if the pinless accumulators I put in have something to do with it.
The rest of the shifts are quite nice, no harshness to any of them, it's noticeable that it shifted, but nothing that worries me, although the 3-4 when it locks up the convertor is a little firm, but the normal 3-4 is fine.
I did see that plate, but was apprehensive about ordering it, since the nalley gm site shows 2 for the 2007, one for units prior to 12/01/06, and one for units after that date, I'll call the dealer I picked mine up from and ask about the 2 different ones, the part number I have shows its for a 2004-2006, so pretty sure it's incorrect.
The biggest pain was dropping the pan, and keeping the bolt sizes organized, a piece of cardboard helped out a ton with it though. I started the install at 1:30, and with the 3-4 hours of shooting, finished at 7:30ish, then did a plug change, since I'm at 86k on the oems ones. Not sure if it was the plugs, or a combo of the 2, but my mpg is now at 21 according to the dic, up from 16 hwy, probably from the instant lockup of the tcc, although that was only a 40 mile drive home from the garage I work on it at.
Chris, I used dex 6 in mine, but that's what it came with, and I've heard from the os that people use it all the time in older ones, without issue.
