So as I was going through the process of working on my ext temp sensor, I noticed a large red wire was undone from what looks like it supposed to be attached to the third post of the fuse block on the driver side. The attached pics are how I found it. My question is, what does it go to and should it be or not be fastened down? There is no nut on the post itself and both sides of the metal flat attached to the wire look slightly corroded and dirty which leads me to believe it's been undone for awhile now but have no way to verify.
Thanks!
Josh
