Have a broken splined disconnect housing? I want your guts.
by fishsticks » Fri Jan 20, 2012 5:40 pm
Finally pulled my passenger side axle and pieces of my AWD sleeve fell out. Guess they are weak too.... :hissyfit:
Since I'm taking it easy with the TB now I think I can make normal splined disconnect parts work for my mission. Plus I'd rather put some money into a member's pocket instead of GMs.
What I need:
Both gears - Worn teeth OK, but not broken. Bearing surfaces in good condition. Splines need to be good... but I think the only person who's had problems with that is me anyway. :mrgreen:
Shift Collar - Same as above, worn or chipped OK, but no missing teeth or cracks.
Thrust Washers (3) - If yours are toast it's OK, I have the dimensions and can source these locally.
I don't need a shift fork or spring, as I'm just going to tack the collar into place like I had done previously. I'm not picky though, so if you just want to throw what you have into a box and send it to me, I'm fine with that. No need to disassemble it.
I'm looking to spend around $50 + reasonable shipping. Any more than that and I might as well just buy a new sleeve.
Preference given to local deals as always, but I'm not picky. Show me what you got!
by fishsticks » Fri Jan 20, 2012 6:11 pm
That was quick. :mrgreen:
Looks like I got what I need. Thanks Mario.
by DirtyBacon04 » Fri Jan 20, 2012 6:27 pm
I'd offer you my gears...........
by Nakashige » Fri Jan 20, 2012 9:35 pm
I have one as well unknown condition
Nakashige
Vendor
