offroadTB.com • View topic - 4Crawlin Build Thread
by bartonmd » Thu Nov 10, 2011 11:04 am
110 is too cold... You really want it to get to 160F, which is considered "warmed up" by the manufacturer, and is the temperature that the valves and such are meant to work...
by chevycrew » Fri Nov 11, 2011 3:09 pm
My crew cab, all factory coolers, runs in the low 100s as well untill I hit a hill or towing. I have no issues with how the trans acts at low temps. On the TB, If I use cruise control, or start wheeling, the temps shoot up quickly.
by chevycrew » Fri Dec 02, 2011 5:53 pm
update... I knew something was fishy with my rear case (trying to pop out of gear). After the last wheeling trip the bolts pulled out of front of the doubler (front case) causing a leak. So I dropped everything out, and opened up the rear case. I lost the input planetary, the range gear, range fork, and filled everything else with metal shavings.
Im guessing the shock from it repeatedly popping worked the bolts loose untill they pulled out. I just need to oversize the doubler mounting bolts, install my spare rear case (after putting in a 32 spline input, and SYE), add a rear case support/mount, and I should be back wheeling.
On a positive note, with the cases out, I was able to hook up my ebrake cables and cross that off the list!
by Hatchet669 » Fri Dec 02, 2011 8:25 pm
always look at the positive... u trashed out a case and lost some time.. but you got those pesky cables lol
Hatchet669
by chevycrew » Sat Dec 03, 2011 5:09 am
Which is really odd for me, my wife says I'm always looking at the negatives!
by chevycrew » Sun Dec 11, 2011 2:27 pm
Took it out again, works great. Ran a local canyon, nothing really hard but it was muddy, rocky, with snow and ice. Good day overall and picked up a ton of trash (it was actually a cleanup with trail run).
I need to trim the front fenders in front of the tires behind the headlight, thats where im rubbing now at full stuff.
Stopped for a pic:
by dirty anton » Sun Dec 11, 2011 6:53 pm
looks awesome! brake line.....
dirty anton
by chevycrew » Sun Dec 11, 2011 7:44 pm
It looks a lot tighter than it is. If it ever breaks, ill relocate.
Also I was playing pretty easy in the snow with the TB and watched the trans hit 200 degrees pretty easy with an aftermarket cooler. Im considering adding an electric fan to the trans cooler for slow speed wheeling.
by chevycrew » Mon Dec 26, 2011 10:53 pm
Took out the TB again, beat on it pretty hard.
Carnage:
Scraped up all 4 wheels
Bent both sliders
Broken headlight, grill, cb antenna, and winch box
Pulled apart front d-line (Need to upgrade to long travel)
But Im getting more used to it and its doing really good
by fishsticks » Tue Dec 27, 2011 1:24 am
by v7guy » Tue Dec 27, 2011 3:43 am
by chevycrew » Tue Dec 27, 2011 4:24 am
I took a couple poser pics but that was it. Just big rocks on the sliders, caught a tree with the headlight, different tree got the antenna, 6' waterfall got the winch box, and a nastly climb got the d-line. I'm working on some carnage pics now.
by chevycrew » Tue Dec 27, 2011 4:39 am
by djthumper » Tue Dec 27, 2011 1:37 pm
Man, talk about tearing some stuff up!
by chevycrew » Tue Dec 27, 2011 3:22 pm
So the headlight is fine, but I shattered the mounting bracket for it. (Would have rather it been my foggy headlight instead!)
by v7guy » Tue Dec 27, 2011 5:17 pm
Do you know at what point you bent the slider?
by chevycrew » Tue Dec 27, 2011 5:26 pm
To climb one spot I bounce off the driver slider pretty hard, but the passenger was just my tire slipping off a rock and the weight of the rig landing on the rock right behind the tire. That outer tube is 1.75 wall DOM, with 1.5" DOM tube inside of it.
I plan to cut these apart and do some modifications. Directly under the rocker Im going to replace the tube with 2x2x.25 wall box tube against the body, then reattach the outer bars and tie in some fender hoops to help strengthen the ends.
The problem is the frame is twisting and bending where the sliders are attached to the frame, there just isnt enough thickness there.
by bartonmd » Tue Dec 27, 2011 5:29 pm
by chevycrew » Tue Dec 27, 2011 5:41 pm
Yeah, around the plates is where its bending.
by bartonmd » Tue Dec 27, 2011 5:42 pm
