offroadTB.com • View topic - Fixing my steering today...
by OregTrailBlazin » Tue Nov 01, 2011 1:22 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by Trail X » Tue Nov 01, 2011 1:34 pm
by Rob93 » Tue Nov 01, 2011 1:40 pm
Rob93
by OregTrailBlazin » Tue Nov 01, 2011 2:09 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by fishsticks » Tue Nov 01, 2011 5:02 pm
Don't worry, the uppers are coming down an equal amount to the lowers...
...as is the front diff. :coffee2:
Then I just need a set of coil-overs that won't break...
by fishsticks » Tue Nov 01, 2011 8:37 pm
Found one of my wheelin crew with a 7 degree reamer I can borrow. :mrgreen:
by The Roadie » Tue Nov 01, 2011 8:46 pm
by OregTrailBlazin » Tue Nov 01, 2011 8:55 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by fishsticks » Thu Nov 03, 2011 3:18 pm
Mike was right. (No surprise there).
With the tie rod on top, unloading the suspension causes enough of a shift in toe to make driving the truck VERY interesting over bumps.
Fortunately, there's enough meat in the knuckle that I can taper the bottom as well. I'll shift them to the bottoms until I can get the "other" project done then flip em over again.
by fishsticks » Sun Nov 06, 2011 1:36 am
New hardware...
Old bushings were pretty well shot. I haven't had them apart yet but the truck rides so differently now. My wheels are actually the same distance away from the sliders now too! My old ball joints are well worn, but still serviceable (no slop). The old arms will make good trail spares and mockups for the next project.
I garage aligned the truck for maximum positive caster (front adjustments all the way in, rears all the way out) and got the toe pretty dead on. The truck tracks straight as an arrow with no hands on the wheel. 8-) I have a slight negative camber that I may try to fix. Right now I'm close enough that I think I can cross a rack alignment off the list.
Before pic:
After pic:
by bartonmd » Mon Nov 07, 2011 10:40 am
Wait... So you have 1 side coming from the bottom and 1 side coming from the top on the TRE?
by Regulator1175 » Mon Nov 07, 2011 11:10 am
by TBNewbie » Mon Nov 07, 2011 11:18 am
Is the reason for the curved tie rod clearance and now that we run adapters we can run straight ones?
TBNewbie
by Trail X » Mon Nov 07, 2011 11:23 am
Exactly. Stock, the tires are tucked in so tight, they would interfere with straight tie rods on full lock.
by navigator » Mon Nov 07, 2011 11:32 am
so if I read this thread right to upgrade our inner TRE we can:
get a 7degree reamer and ream out our knuckle
buy TRE for a 2500 silverado and it is pretty much a direct swap.
am I following this right?
by fishsticks » Mon Nov 07, 2011 11:46 am
You got it.
by Trail X » Mon Nov 07, 2011 12:02 pm
Still unsure about the inner thread diameter though. Did we ever determine what that was on non-2002s?
by fishsticks » Mon Nov 07, 2011 12:06 pm
by Trail X » Mon Nov 07, 2011 12:30 pm
Rack side is 18mm on mine.
by fishsticks » Mon Nov 07, 2011 12:40 pm
