by navigator » Wed Aug 31, 2011 10:13 am
Bill, at first glance I wouldn't have thought any issue with that front spacer.
On the issues with the CV/ball joint is it because since it is outside of the strut you get 3 inches of lift in addition to your added extension from the strut?
I guess I mean it will flex 3 more inches which will over extend the CV, cause it to hit the oilpan and over stress the ball joint.
As far as safety, is the issue that it could overstress the ball joint or that with the way it is designed the strut actually acts like a lever which could break the spacer itself? I also expect that having another set of bolts also acts as another point of failure.
