BUILD THREAD COMMENTS GO HERE
Document your truck's build, start to finish.
One thread per member is allowed.
NO DISCUSSION is allowed in the build threads, comments from users other than the thread author will be deleted. Please place links to specific modification threads. All comments can go here: viewtopic.php?f=25&t=2041
Please keep the first post updated with a list of your modifications.
The first post should follow the guideline and layout listed on this thread: viewtopic.php?f=25&t=79
Thanks - The ORTB Team
by fishsticks » Sat May 21, 2011 6:35 pm
CBRguy wrote:Thanks. It was tighter under there than I had hoped. But I managed to fit all the relays under the console. The bottom two are already pre run and terminated for when I get the rest of the lights and the basket. All I will have to do is connect the power to the switches and relays. :cheers:
I just saw this. Great minds must think alike! I have 5 running horizontally in the same place. Not all of mine do something at the moment but I put them in when I did my OBA.
Looks good! :cheers:
by BSalty » Sat May 21, 2011 8:16 pm
:need pics:
How did you fit 5? I was going to do 5 until I started measuring between the supports molded in on the bottom side. I couldn't make it work without cutting out the front support. I had to trim it a bit with the dremmel to fit 4. Thats sweet that you made it work with 5.
BSalty
by Diacom » Sun May 22, 2011 5:06 pm
May be smaller switches or they are closer together. I like the look, but beings my co-pilot likes to lay in that area, this wouldn't work as a functional location for me.
by fishsticks » Mon May 23, 2011 11:04 am
I have 3 of the switches out right now... I assure you they all fit though. :) I also had to notch one of the supports underneath. Sorry for the incomplete picture.
Maybe this will make up for it?
:mrgreen:
by Gordinho80 » Mon May 23, 2011 11:14 am
OOOH... not bad!
by navigator » Mon May 23, 2011 12:15 pm
Conrad, you have a great build thread going. I noticed in your build thread it appears you chopped off your resonator and just stuck the factory tip back on making it several inches shorter. Does it concern you that the exhaust fumes will cause premature rust? Exhaust leaks are a major contributor to premature rust at least in older vehicles, I would think shortening the exhaust that much wouldn't be good.
viewtopic.php?f=25&t=1814
by djthumper » Mon May 23, 2011 12:31 pm
Donny - I have been thinking of something similar for the back bumper. That looks good, I hope it works out for what you have planned.
by ConradM » Mon May 23, 2011 1:50 pm
navigator wrote:Conrad, you have a great build thread going. I noticed in your build thread it appears you chopped off your resonator and just stuck the factory tip back on making it several inches shorter. Does it concern you that the exhaust fumes will cause premature rust? Exhaust leaks are a major contributor to premature rust at least in older vehicles, I would think shortening the exhaust that much wouldn't be good.
Rust in the exhaust? Or just rust in general?
ConradM
by fishsticks » Mon May 23, 2011 2:10 pm
djthumper wrote:Donny - I have been thinking of something similar for the back bumper. That looks good, I hope it works out for what you have planned.
It's a work in progress. I wanted to have it done by the wheeling trip next weekend. Sine I've had Camaro on the brain I hadn't even started on it until this last weekend.
by Trail X » Mon May 23, 2011 2:14 pm
1.5" OD Tube? Strong enough you think?
Looking forward to seeing the completed version. Swing outs rock! :fro:
by fishsticks » Mon May 23, 2011 2:28 pm
JamesDowning wrote:1.5" OD Tube? Strong enough you think?
The "base" welded to the frame and stabilized on top as well.
If I had it to do again, I'd have used square tube I think. Easier to work with. Everything so far is rock solid except for my hinge, which has some movement in it. :wallbash: It's functional right now, and I won't have much more time to work on it, so it will be in "work in progress" mode for the coming weekend. Open tube ends and non-ground welds will be plentiful.
I also had some slag drop and burn through my shoe (and into my foot). Many obscenities poured forth as I hopped around on one foot while ripping off my shoe. I will not post pictures of the results of that...
by navigator » Mon May 23, 2011 2:29 pm
My expectation would be the floorpan in the rear near the bumper, and the bumper itself.
If you think about where those exhaust fumes will collect is where I would expect rust.
by bgwolfpack » Mon May 23, 2011 3:23 pm
fishsticks wrote:Image
Good to see you're still taking your medication. :finger:
Are you going to sell the other tire carrier?
by ConradM » Mon May 23, 2011 4:16 pm
Rust in the exhaust? Or just rust in general?[/quote]
If you think about where those exhaust fumes will collect is where I would expect rust.[/quote]
Nah, I'm not to worried about it. When I was HS I had a turned down exhaust dumping right below the drivers seat in my pickup... This was in Guam where rust was already a problem.
ConradM
by fishsticks » Mon May 23, 2011 6:18 pm
I get off my meds and do shit like install lockers and plan out IFS diff drops. One could argue that a bat shit crazy Donny is good for the off road TB community.
I backed into a tree with the other carrier and tweaked it a bit. It works fine but the tire doesn't quite center up... you could probably bend it back. I pulled some of the hardware off of it to use on the new swing out.
I was going to just cut it up for randomness, but if you're interested you can have it for scrap value (20 bucks?).
by galacticfuzz » Wed May 25, 2011 1:31 pm
Donny,
Thank you for posting that pic of your swing out setup, definitely gave me some ideas for my eventual spare tire mount. Playing with the idea to do something similar except incorporating a rear bumper guard.
― Antonio Porchia
galacticfuzz
by BSalty » Fri Jun 10, 2011 8:56 pm
Fish I tried that direction. My switches hung out about 1/16"-1/8" over the edge of the console. I was afraid I would catch it with my pant leg and rip stuff off. I like that better than mine though.
Your rear tire carrier is freakin sweet. I have been trying to figure out how to do mine to avoid the hitch mount type, yet keep the stock bumper cover. I know my welding/metal fab/ tool access limits and I can't do the full replacement steel bumper at this point.
BSalty
by fishsticks » Fri Jun 10, 2011 8:59 pm
CBRguy wrote:Fish I tried that direction. My switches hung out about 1/16"-1/8" over the edge of the console. I was afraid I would catch it with my pant leg and rip stuff off. I like that better than mine though.
Piece of advice... don't wheel with it until you're done. I had a couple spots I hadn't welded up completely and they promptly broke. The carrier came home in the bed of my buddy's pickup.
Cranked that welder up when I got some and burned the shit out of those spots. :mrgreen:
by Diacom » Fri Jun 10, 2011 9:08 pm
Was a recent article in one of the off-road mags where they added a rear carrier to the back of a 4-runner being build up. They put it through the factory bumper.
I didn't notice what brand or if they just went straight to the frame as it wasn't that detailed, i'll do some digging and find which mag it was out of for a reference.
by Trail X » Mon Jun 13, 2011 3:39 pm
ConradM wrote:More visual updates for my TB... I found out about this stuff called PlastiDip which is basically spray on rubber. Requires no prep aside from cleaning and you can peel it off... I hate chrome so I sprayed the only bit of chrome I had left.
Going to use this stuff for the wheels too. :excited:
Looks good man, but I worry about it being able to stick to wheels... especially since you said it can peel off. There are massive centrifugal forces on a wheel... you don't want the plastidip to just fly off. Maybe test it somewhere first?
Return to Build Threads
