by janesy86 » Mon Aug 22, 2011 4:21 pm
Finally got around to fixing my A/C, even tho the summer is mostly over... I had been having a whine that went with RPM change, I knew it wasn't the idler bearing since I changed that only 6 months ago. Narrowed it down to the A/C compressor since the noise went away when the A/C was on. Didn't want to shell out the $$ for a new compressor so I just went with a shorter belt to bypass the A/C for the last 5 months or so.
Found a thread on the OS about it possibly being the bearing, which it ended up being. So I just picked up a new bearing for it and decided to replace it this weekend since I also needed to replace my fan clutch. It was a pain to remove, but it is all fixed and works great again! And now that I got the fan clutch replaced, its not constantly turning with the motor, so now I can prob look to be getting some mileage back!
If only I had time to replace my front diff seal which has being weeping for the last year now... Oh well, maybe next time I fix stuff on the truck.
