Steveroche's Build - 2003 Chevy Trailblazer
by steveroche » Fri Apr 29, 2011 10:46 pm
Steveroche's Build - 2003 Chevy Trailblazer LT
Drivetrain Specs: 4.2l I6, 4x4
Suspension Modifications:
Mark MC Front 3in Spacers
BDS 2in rear lift kit
87 front springs
Tahoe rear springs
Flipped Upper Control Arms
3in Body lift
Exterior Modifications:
Custom front winch bumper
Painted grill with truck bed liner
Removed running boards
265/75/16 BFG Mud Terrains
1.5in wheel spacers
Painted wheels with black Plasti-Dip Spray
CB Radio antenna custom mounted to rear bumper under taillight
Roof mounted off road lights:
4 on front roof, 2 hanging from front bar, 1 on each roof side, 2 on rear
MDB Radiator and oil pan steel skids
Engine Modifications:
None so far
Interior Modifications:
Sony Xplode Head unit
Full set of Kicker door speakers
Cobra CB Radio
Recovery Equipment:
Smittybilt XRC-10 winch
Smittybilt 3"x30' 30,000lbs recovery strap
Electrical Modifications:
None so far
Future Modifications:
Gas tank skid, swap for an EXT 8.6 rear axle and powertrax no-slip locker, Raptor line the whole truck olive drab green, Hidden Subwoofer/amp combo under passenger seat, Hanging fog lights from steel bumper, HI-Lift jack, Roof basket, Front swaybar quick discos...
Current Pic:
steveroche
by steveroche » Fri Apr 29, 2011 11:17 pm
The beginning...
Bone Stock right after purchase...
steveroche
by steveroche » Fri Apr 29, 2011 11:21 pm
A little fun in the mud...
Ripped off the running boards, hit a small trail
Got stuck in a mud pit...time for new tires and a lift!
Disassembled right before i painted up the front..
steveroche
by steveroche » Fri Apr 29, 2011 11:25 pm
Paint...
Anti-Rust primer...
Painting the grill, used spray on bed liner. Very pleased with the results...
Finished up painting, finished product.
steveroche
by steveroche » Fri Apr 29, 2011 11:27 pm
Lift kit!
New Bilstein HD's
Right out of the box...and it begins
After assembling the front struts
steveroche
by steveroche » Fri Apr 29, 2011 11:29 pm
Some more lift stuff...
Shocks installed
Struts installed!
Got my spacers in the mail, tires coming!
steveroche
After Lift...man those tires look small
steveroche
by steveroche » Fri Apr 29, 2011 11:31 pm
Costco guy brought them up to the front to make sure these were going to fit...I guess Costco doesn't usually let people install non-stock size tires but they wanted to see what it would look like so they let me do it..
steveroche
by steveroche » Fri Apr 29, 2011 11:34 pm
Well this is as far as i have been able to get...next upgrades will come late may when i get back from my trip to Germany
So much for articulation... :/
steveroche
by steveroche » Tue Aug 09, 2011 11:43 am
Pictures to come when i get out of work at 3 today but I will at least update what has gone in the truck the past week.
Wheels painted with Plasti-Dip spray black
Cobra CB Radio and radio shack antenna installed
Resonator hacked off and replaced with straight pipe and Chevy exhaust tip
Things to come before the end of August:
Custom Winch bumper made from steel plate and 1.75OD Steel Tubing
Smittybilt XRC-10 Winch
Mikes Radiator and Oil Pan skids
EXT Rear axle w/Powertrax no-slip locker
steveroche
by steveroche » Tue Aug 09, 2011 9:37 pm
So here is a front view to show how high the antenna goes above the roof, as well as pictures of the straight pipe which replaced the resonator and the fun little Chevy exhaust tip i threw on there for kicks...
More pics tomorrow of the antenna mount I made up and CB location...
steveroche
by steveroche » Sun Aug 14, 2011 6:45 pm
New lights installed today...about an inch of clearance between lights and top of garage.... :awesome:
steveroche
by steveroche » Thu Sep 01, 2011 10:07 pm
New front winch bumper made, Base of bumper made by Mike Barton, tubing and finishing work done by myself.
steveroche
by steveroche » Wed Mar 28, 2012 3:48 pm
Added some lights for the rear of the TB. Two flood lights facing backwards attached to the cross bar at the back.
steveroche
by steveroche » Mon Apr 09, 2012 6:23 pm
Today I added some new lights to the bar of 4 on the front. The two new ones are long range high power lights, I have them wired so i can have the outside ones on or the inside ones on independently. I also finally got around to flipping my upper control arms.
steveroche
by steveroche » Wed Oct 17, 2012 6:39 pm
Body lift installed as of Yesterday 10/16/12
Next up is throwing on the rock sliders I have laying out in my basement waiting to be welded on. As well as new tires, I will be getting 285/70/17 Toyo at2's
steveroche
