The Roadie wrote:They're just skinny - thin tube. Less mass to absorb heat, so they are sized to work OK for paved roads and short runs on gravel. Longer runs like 20 miles down a desert wash at 40 MPH at 110 degrees with bumps and some washboarding and they'll overheat, and perhaps blow out the seal. I've done that to three sets of rear shocks so far, and am hoping to warn others of the risk.
I've been advising people who buy the Z71 takeoff springs from Ebay to not use the shocks. Get the longer ones from BDS that go with their lift kits, and if you're upgrading now, hold out another week or so and I should have a new part number from BDS to recommend.
It's doubly important for you and me who are carrying hundreds of pounds of expedition gear and are close to (or over) GMVW.
Stock trailvoy shocks are even more of a joke. I took mine off at 9K miles, still in warranty and they sucked.Philberto wrote:Ahhhh.... gotcha. I was rather curious about how the z71 shocks weren't much larger than the stock ones... However, what makes the BDS ones potentially better than say, rancho/skyjacker/fabtech, etc shocks for a tahoe? (assuming they make them... haven't looked yet)
The Roadie wrote:Stock trailvoy shocks are even more of a joke. I took mine off at 9K miles, still in warranty and they sucked.Philberto wrote:Ahhhh.... gotcha. I was rather curious about how the z71 shocks weren't much larger than the stock ones... However, what makes the BDS ones potentially better than say, rancho/skyjacker/fabtech, etc shocks for a tahoe? (assuming they make them... haven't looked yet)
BDS shocks are better than their competitors shocks, most other things being equal, because they support our platform. The other guys deserve NONE of our loyalty, IMHO. BDS made the first serious lift for functional offroading - gutsy move - copied by almost none of their competitors.
If they make their investment back, we might get MORE products. If they see no support from us, the supply chain dries up. I can't stress this enough. Hint. Hint. Winky-wink.
I run with their stickers I believe in them so much.
A nice complete kit rather than having to include the bilstein HDs.
bgwolfpack wrote:BDS does not warranty the shocks they sell, only hard parts.
I've personally had BDS step up and replace my gas shocks - free of charge!! Here's some info for folks interested in their warranty info:BDS wrote:BDS Suspension Co. warrants to the original retail purchaser that its Limited Lifetime Warrantyshock and stabilizer cylinders are free from defects in material and workmanship for so long as they own the vehicle. Excluded from this warranty are the finish of the product and mounting bushings. Defects in material and workmanship do not include such things as dented cylinders or bent rods caused by obvious side impact, rust, worn or deformed bushings. A shock absorber is a wear item and over time will experience diminished damping resistance due to normal component wear. This is not a defect in material or workmanship and is therefore not warrantable.
teebes wrote:bgwolfpack wrote:BDS does not warranty the shocks they sell, only hard parts.
Whoa thereI've personally had BDS step up and replace my gas shocks - free of charge!! Here's some info for folks interested in their warranty info:
http://www.bds-suspension.com/Company/w ... p#warrantyBDS wrote:BDS Suspension Co. warrants to the original retail purchaser that its Limited Lifetime Warrantyshock and stabilizer cylinders are free from defects in material and workmanship for so long as they own the vehicle. Excluded from this warranty are the finish of the product and mounting bushings. Defects in material and workmanship do not include such things as dented cylinders or bent rods caused by obvious side impact, rust, worn or deformed bushings. A shock absorber is a wear item and over time will experience diminished damping resistance due to normal component wear. This is not a defect in material or workmanship and is therefore not warrantable.
The Roadie wrote:I'll be able to post about the alternatives as soon as BDS gives me a part number for the upgraded shocks PLUS the mounting hardware. I just obtained the naked shocks with BDS engineering's advice and already had hardware in stock.
Chug-a-lug!
If they would be a voice here and on the os Markmc might not get so many free sales. At least he puts in the time needed, which isn't much.The Roadie wrote:I asked.Too many forums.Roadie you don't seem that timid.Too little time.Too little effort.I'll protect their interests here and be a go-between.Not for a good salesman.And poke them as often as I can with new product requests as long as folks keep BUYING their stuff for the platform.Are you getting a spiff?
