chevycrew wrote:That pesky oil pan....
Looks like there is going to be some custom work on that big thing. About the only way to clear it, is run about 14" of suspension lift. Thats just too tall.
At least with the axle Im running, the diff itself will be offset enough to the drivers side to clear. Now I just have the issue of axle tube to drain plug. (Im pushing the axle forward 4-6")
I assume you'll cut it up and TIG some aluminum plate together. The biggest issue being that the oil pickup is in the front of the sump:
This gives you an idea of what you're going to be working with on the inside of the pan:
You can probably raise the area a good 5" or so, but you'll have to have an external sump or something to keep the capacity at 7 quarts.
I'd also consider adding internal baffles to keep the oil wherever your oil pickup is. Currently it's at the deepest part of the pan and doesn't seem to starve the engine of oil very often (a couple people have reported low oil pressure when going up steel banks though). But you seem pretty smart, so I probably didn't need to state the obvious.
Just some food for thought.
